Won't stay running
HARLEYMAN2010
  • 2003 KIA SORENTO
  • 3.5L
  • V6
  • 4WD
  • 140,000 MILES
The car will start and run for 5 minutes and then dies. Code came up p0340 cam sensor changed it and it still won't stay running.
Friday, March 14th, 2014 AT 4:21 PM
HMAC300
  • 48,601 POSTS
It sounds like you have a dirty throttle bore and it needs to be serviced here is a guide top help you step by step.
Saturday, March 15th, 2014 AT 6:57 AM
BOOPERIII
Thanks for this post I had this problem and followed the guide worked perfect! I love this site.
Thursday, May 30th, 2019 AT 8:20 PM
ALBOOTH79
  • 2003 KIA SORENTO
My car first died while sitting at a stoplight then wouldn't start back up, so I had it towed home, then we go out to look at it and it starts so I drove it then it did it again this time it died while I was driving down the highway. It wouldn't start back up right away but after letting it sit for about 20 minutes it started back up and I made it home.
Thursday, May 30th, 2019 AT 8:21 PM (Merged)
HMAC300
  • 48,601 POSTS
Check your fuel pressure and scan for codes first, Sounds like a crank sensor going bad
ALBOOTH79
How/where do I check the fuel pressure? I have the gauges but can't find the place to hook it up to to check it.
HMAC300
  • 48,601 POSTS
You need an adapter which you probably don't have. An auto parts store may have it pic enclosed.
PAULSMITH39642
  • 2003 KIA SORENTO
  • 108,000 MILES
I have manual diesel sorento that for the last 6 years has performed flawlessly. However, last week the following happened 3 times in 1 trip.
I was towing my exhibition trailer (approx 2.3tonnes) and when I tried accelerate from a roundabout, junction or go up a steepish hill the engine would "feel" like it misfired, and would then die when I depressed the clutch. Turning off and restarting and all would be fine. After the second failure I noticed that the engine check light came on. After the third failure I completed the journey by ensuring that I did not put the engine under any undue strain (under 2000 rpm),
Once I reached the destination, I unhitched the trailer and use the car normally. I also noticed the following day that when I started the engine check light was out, and stayed out.
After completing the event, I towed back and deliberately avoided any strain, and had no failures and the engine check light did not illuminate.
KHLOW2008
  • 41,814 POSTS
Get a scan to retrieve the troubel codes to see what it says.
The fuel filter might require replacement.
PAULSMITH39642
The closed have been downloaded and are u0006 and u0010, both of which according to google suggest a cam sub issue.
I've managed to recreate the issue in normal drivi g bu heavily accelerating / revving the engine, and the check light seems to Rees after 12 hrs.
Hopefully I wont need to pay dealer rats to get to the bottom of this.
The car does do some offloading as I photograph wildlife and equine sports so go across fields and muddy tracks
KHLOW2008
  • 41,814 POSTS
This could be due to the oil quality and level. If oil change is due, replace it and ensure oil level is correct.
TURKSCREW5
  • 2004 KIA SORENTO
  • 120,000 MILES
I can drive it for a while and motor just shuts down, lights radio heat all are working fine and strong but motor just shuts off. All belts are fairly new within year and just replaced the alternator.
Sunday, August 4th, 2019 AT 12:02 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
This sounds like a classic crankshaft angle sensor which usually will not trigger a check engine light. Here is a guide to show you what you are in for when doing the job with diagrams below to show you how to fix your car:
Cheers
GWENG7
  • 0 POST
This worked for my car cost me $56.00 for the sensor. Have not had a problem since!
TZEAST
  • 2004 KIA SORENTO
Engine Mechanical problem
2004 Kia Sorento 6 cyl Two Wheel Drive Automatic
Engine just died. No warning, no surging, no sputtering. Someone said it sounded like a fuel pump. But the pump turns when cranking, but does not pressure up when key is on. Again someone else said a bad relay. I switched out the relay but no change. I will not start at all. But the pump runs while cranking. Disconnected gas return line and then cranked again. I seem to have gas pumping through line, although I am not sure what is normal pressure. But the pump is still turning when cranking.
  • 108,328 POSTS
Are you getting spark to the engine? Also, here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Check that and let me know what you find. Finally, is the check engine light on?
TRAYDORSETT
  • 2003 KIA SORENTO
  • 6 CYL
  • 4WD
My 2003 kia sorento will crank but will not start - it was doing this only when the car was warm now it will not start at all
WRENCHTECH
  • 20,758 POSTS
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
PEPS ONE
My kia sorrento was in a front crash, it cranks but wont start does it have a engine kill switch for crashes
