Door locks not working correctly?
PANDACTK
  • 2008 SUZUKI FORENZA
  • 66,000 MILES
The automatic door locks work but when you push the unlock button the door unlocks but it keeps making noise like it is till trying to unlock.
Need more information please ask as I have no idea how else to ask or describe it.
Sunday, November 17th, 2013 AT 7:35 PM
KHLOW2008
  • 41,814 POSTS
The door lock switch might be faulty but to be sure here is a guide to help check the wiring and the door lock wiring diagrams so you can see how to test the system wand how ti works.
Tuesday, November 19th, 2013 AT 10:41 AM
PANDACTK
We found out that in response to my recently asked question about the door locks was the battery was very low. Bought a new battery and everything is working well now.
Pandactk
Sunday, December 8th, 2013 AT 6:49 AM
WISMU2U
  • 2007 SUZUKI FORENZA
  • 80,000 MILES
Our automatic car locks are reandomly locking and unlocking on their own. The car can be moving or sitting parked. What is causing this and how do you fix it. We have a 2007 Suzuki Forenza. Thank you for your advice.
Thursday, December 19th, 2019 AT 2:28 PM (Merged)
  • 108,320 POSTS
It could be a few things, a bad relay, short to power, or bad ground. Have you checked for any of these things?
TMOLLA
  • 4 CYL
  • 89,000 MILES
When door lock is pressed, all of the doors lock and unlock over and over
KNOWLEDGE IS POWER
  • 1,136 POSTS
Is the security light on the cluster flashing at all? It could be a problem with the antitheft. If not then check all the locks on all the doors and make sure none of them are stuck. Operate them all by hand even the trunk
