1985 Dodge Truck Ignition Problem
1985 DODGE TRUCK
DAVE HECKMAN
Electrical problem
1985 Dodge Truck V8 Four Wheel Drive Automatic 200K miles
My truck will not start. You can hear the solenoid "clicking" when turning the key. I checked the battery and it's terminal connections and cleaned w/ a terminal brush...still hear the solenoid clicking when attempting to start. No obvious disconnected or bad wires that I can see. I bypassed the ignition and used a screw-driver at the solenoid and still it clicks. I connected battery cables to make sure I had maximum voltage and ran up the RPMs to charge my truck's system and still ... the solenoid clicks. I checked the battery also by turning on the headlights and windshield wipers and the headlights were bright and the wipers work. Now, I haven't been driving the truck much and l should be starting it far more often than I do because most of the time now I do notice that the battery seems low as the the engine sometimes will turn slowly and other times it will seem fine when starting. I use an OPTIMA brand batterry. Do you think it is in fact my battery?
Mar 4, 2008 at 12:24 PM
