Possibly, but that will usually set a code. Is the check engine light on? Try cleaning out the throttle bore with a little carb cleaner and a rag. Also find the fuekl pressure regulator, it is on the fuel rail and has a small vacuum line to the intake. Check for fuel in this small line, if any is present replace the regulator.A blown reg can make it run rich and need a little more air to start
Monday, December 29th, 2008 AT 5:55 PM
