This Jeep lost oil pressure, and in taking it apart, the oil pump drive was broken where it connects to the shaft that drives the oil pump. The oil pump had not seized, neither was there any evidence of wear (scarring, color change). The oil pickup screen was clear. This engine was reportedly rebuilt about 2 years ago. I replaced the oil pump, main bearings and rod bearings and I still have low oil pressure. (When the engine is cold the max is 30 psi and as it warms the pressure drops close to zero at idle.) Any ideas?
Oct 30, 2008 at 10:01 PM
