HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Ram
Engine
Symptoms
Not Running
SPONSORED LINKS
1997 Dodge Ram truck wont start
JDBUR1103
MEMBER
1997 DODGE RAM
V8
4WD
AUTOMATIC
150,000 MILES
Battery is good, put it in park, no start, same with neutral. All lights work and but my truck wont start.
Saturday, December 5th, 2009 AT 5:02 PM
MECHANIC
Is it cranking over and will not start or just won't crank at all/nothing/nada?
SPONSORED LINKS
Saturday, December 5th, 2009 AT 5:29 PM
JDBUR1103
MEMBER
It wont crank at all, all lights work and battery is ok.
Saturday, December 5th, 2009 AT 5:48 PM
MECHANIC
Your possibilies here could be one of the following-starter, starter relay, transmission range switch and ignition switch-
Saturday, December 5th, 2009 AT 5:50 PM
JDBUR1103
MEMBER
Is the transmissoin range switch the same as the neautral start switch?
Saturday, December 5th, 2009 AT 5:52 PM
MECHANIC
Same function just different names
SPONSORED LINKS
Saturday, December 5th, 2009 AT 6:16 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Dodge Ram Truck Turns Over, Will Not Start
I Have Just Replaced The Moor In My Truck. 318. The Truck Turns Over, But Will Not Start. I Unplugged The Harness From The Coil And Put A...
Asked by
bear42229
1997
DODGE RAM
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting - Top 3 Easy Steps
Over the past 20 years on 2CarPros we have identified the top three problems that are easily fixed. This can save you a trip to the repair garage or calling a tow truck and...
My Truck Will Not Start In Park Or Reverse, The Lights...
Will Not Start In Park Or Reverse When Turning The Key But The Lights On The Dash Will Get Brighter And Nothing Happens With The Starter....
Asked by
richyrich95
1997
DODGE RAM
1997 Dodge Ram Engine Wont Start
It Was -20 Out And I Tryed To Start My Truck And It Fired A Few Times But Would't Start, Batt. Went Down So I Put Charger On It With 200...
Asked by
Richs46
1997
DODGE RAM
Acts Like Jumped Time Refuses To Start
Replaced Coil Rotor And The Plugs Wire's, O2 Sensors, Crank Shaft, Timing Belt, Pcm, And A Few Other Things. I Am Disabled Lady And The...
Asked by
Cookie Keller
1997
DODGE RAM
1997 Dodge Ram Runs Great, Turnoff Engine, Will Not...
Engine Runs Great At First, If You Turn It Off And Try To Restart The Engine There Is No Spark From The Coil. You Have To Wait Along Time...
Asked by
caseypap
1997
DODGE RAM
VIEW MORE
SPONSORED LINKS
Not Running - Advanced
Crankshaft Sensor Symptoms
Online car repair manuals
