MY Ac only works on high and it blows very cold but it does not work on low or medium, what are some of the things I can check to keep from payng a Hugh AC repair bill.
Do you
have the same problem?
Wednesday, July 8th, 2009 AT 7:33 AM
BUDDYCRAIGG
MECHANIC
Are you talking about the blower fan only works on high?
SPONSORED LINKS
Wednesday, July 8th, 2009 AT 2:48 PM
WJV1
MEMBER
Yes the switch that turns the air up higher it only blows in the high position.
Wednesday, July 8th, 2009 AT 9:06 PM
BUDDYCRAIGG
MECHANIC
4 things it could be the problem
a fuse.
The blower motor relay
the blower motor resistors
the blower speed switch.
I emailed you a schematic,
it's a 99 full sized pickup, but I think it will be the same.
Wednesday, July 8th, 2009 AT 9:40 PM
AMEGILL
MEMBER
1 POST
2001 DODGE DURANGO
V8
4WD
AUTOMATIC
97,360 MILES
Heater blower only works on high speed
Saturday, August 8th, 2020 AT 10:56 AM
(Merged)
MERLIN2021
MECHANIC
Check for power getting to the resistor, on the heater plenum, the resistor then plugs into the blower, if power is present, replace resistor, if no power, check fuse, and or switch.
