replaced cvjoint axle 1 yr. ago, but again popping & crackling worse & with steering shimmy wooble at speeds of 55-70+ worse as speed increases! 6 auto store clerks & I are not sure which cv joint axle to select for right side, equal or unequal with weighted doughnut or not? What should the left side cv joint axle look like as well? NOTE: This shelby Z has a intermetent trans drive shaft connecting to a bearing hub to where the inner cv joint axle assembly connects!
Oct 19, 2008 at 1:08 AM
