1998 Dodge Dakota Repair Question
Asked on February 22, 2010
Bumper mounting bracket replacement
1998 Dodge Dakota V8 Two Wheel Drive Manual 187000 miles
the front bumper inner mounting bracket on the rh side of my dakota is bent and needs to be replaced. i started to do the job n then realized i have to remove the radiator core support to remove the old one and install the new. how do i go about doing this? im somewhat a beginner so any advice would be helpful. thank you. keep on truckin
Answer
Replied on February 24, 2010
Are you sire it needs to be removed? I believe the bottom is welded to the body and bolted to the frame and the top is bolted. I don't think it is a simple remove the rad support. Also, what is it hitting on the rad support?
