1994 Dodge Dakota truck wont start
1994 DODGE DAKOTA
94,156 MILES • 6 CYL • 2WD • MANUAL
JUMPSTART804
i recently bought a 94 dodge dakota. #5 rod had gone threw the water jacket,no problem i have a 93 donar. i completed the engin swap from the 93 automatic to the 94 manual using everything for the manual in the 94. easy stright swap. ok in the process i broke the crank sensor. now i have replaced the sensor 5 times and the last one i bought to day from a dodge dealer so i got the oem part right. now i have replaced the distributer,coil,wires,cap,roter,and even tryed using the pc from the 93 . now the problem i am having is no fire to the plugs, everything else is working fine . fuel pressure is about 75lbs . pluss you can smell the fuel in the exaust . im just not getting any fire please help. the donar engin ran great befor i did the swap .
Jan 15, 2008 at 11:44 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Did you check the two crank pulleys? If they arent the same part#, your crank sensor may not be picking up a sgnal...attach a voltmeter to the sensor itself and crank engine, any reading? If not swap the crank pulley...no signal= no spark!
Jan 15, 2008 at 11:50 AM
JUMPSTART804
[quote:737d55aaeb="jumpstart804"]Engine problem
1994 Dodge Dakota 6 cyl Two Wheel Drive Manual 94156 miles
i recently bought a 94 dodge dakota. #5 rod had gone threw the water jacket,no problem i have a 93 donar. i completed the engin swap from the 93 automatic to the 94 manual using everything for the manual in the 94. easy stright swap. ok in the process i broke the crank sensor. now i have replaced the sensor 5 times and the last one i bought to day from a dodge dealer so i got the oem part right. now i have replaced the distributer,coil,wires,cap,roter,and even tryed using the pc from the 93 . now the problem i am having is no fire to the plugs, everything else is working fine . fuel pressure is about 75lbs . pluss you can smell the fuel in the exaust . im just not getting any fire please help. the donar engin ran great befor i did the swap .[/quote:737d55aaeb]the crank sensor is located in back of the block and works off the fly wheel. the aftermarkets rubed the fly wheel im not sure about teh oem sensor yet
Jan 15, 2008 at 3:14 PM
MERLIN2021
  • 17,250 POSTS
You may have to swap flywheels...
Jan 15, 2008 at 5:19 PM
