2001 Dodge Caravan Repair Question
Topics covered: Air filter, Door, Evaporator.
Asked on October 30, 2008
A/c cabin air filter
Interior problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 104000 miles
I need to know how can i replace the cabin air filter
Answer
Replied on October 31, 2008
Hello –
Removal
Locate the air filter door on the bottom of the lower evaporator housing just outboard of the passenger side of the instrument panel center stack.
Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the door.
Pull the air filter door straight downward to disengage it from the air filter opening of the lower evaporator housing.
Use your fingers to reach through the air filter opening of the lower evaporator housing far enough to grasp the air filter.
Pull the air filter straight down and out of the evaporator housing.
INSTALLATION
Note the "Airflow" directional arrow imprinted on the foam seal around the frame of the air filter. This arrow should always be oriented towards the center of the vehicle.
With the air filter "Airflow" arrow properly oriented, carefully slide the filter fully upward into the evaporator housing through the air filter opening.
With the latch still positioned against its opened stop, reinstall the air filter door onto the lower evaporator housing air filter opening.
Slide the air filter door latch toward the front of the vehicle until it hits the closed stop on the door.
Make a small donation! (It will help us a lot. We really appreciate it)– information on your car can be found at: http://www.2carpros.com/kpages/auto_repair_manuals.htm
Information on your car can be found at: http://www.2carpros.com/kpages/auto_repair_manuals.htm
