Mechanics
RADIATOR FAN RELAY CONNECTION HARNESS.
2000 Dodge Caravan
Engine Cooling problem
2000 Dodge Caravan 4 cyl Two Wheel Drive Automatic 175185 miles
Gentlemen,
Thanks in advance for your assistance! I'm replacing a radiator fan relay on a 2000 4cyl Dodge Caravan and can't get the relay unplugged from the harness. I'm afraid of damaging the connector which of course I'll need to connect the new relay.
Can you point me to an illustration or advise me on how to unplug the relay from the wiring harness? Also, once installed, if it functions properly, do I need to use the pigtail that comes with the new relay? I'd like to avoid the pigtail splicing if possible.
Thanks sincerely!
chrisxx
Chrisxx
November 10, 2010.
Chances are it is hard to disconnect because it heated up and melted. It should pull out of the socket. As far as the pigtail, if they gave you one, there is a reason or update. If I'm correct and the original one melted down, you will want to replace it.
They gave you that new pigtail for a reason. They have a problem with the plugs melting on to the relay. Cut the wires and splice in the new pigtail.
Wrenchtech
Nov 10, 2010.
Jacobandnicolas/Wrenchtech,
Thank you guys most sincerely for your prompt & informative response! Guess that eliminates any need to know how to unplug the relay from the harness.
Thanks again!
Chrisxx
Chrisxx
Nov 10, 2010.
Your welcome
Sorry Jacob, I missed your post.
AD
Wrenchtech
Nov 10, 2010.
Not a problem. I see we were both on the same page.
Chris, we are glad to help. If you have questions in the future, let us know. Also, pass our webpage on to friends and family, and thanks for using 2carpros. Com.
AD
