1998 Dodge Caravan Speedometer/tranny/gear indicator proble
1998 DODGE CARAVAN
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFSPEACH
My speedometor is stuck at 0 mph, my tranny only has 2nd forward gear(reverse is fine), dash gear indicator shows all gears boxed and lit(at all times vehicle is on), check engine light on with codes P0500(no VSS signal) and P1698(no CDD message from TCM). Replaced input/output speed sensor still same...don't want to replace VSS if is not the problem...any help would be greatly appreciated.
Mar 21, 2010 at 1:47 AM
