Where are the timing marks
1983 DAIHATSU CHARADE
ANONYMOUS
Where are the timing marks on the 993cc three cylinder engine?
What tension are the head bolts tightened down to?
Nov 12, 2012 at 9:01 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Cylinder head bolts are tightened in three steps to 40-47 ft.lbs (54-64 n.M.). Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 13, 2012 at 3:29 PM
JACKRUSSELL
Electrical problem
1990 Daihatsu Charade Manual
On the 1990 Daihatsu Charade 3 Cylinder, Where are the timing marks located?
Apr 2, 2019 at 6:54 PM (Merged)
DAVE H
  • 13,384 POSTS
your local autoparts store will supply a repair manual with the details you need inside
RAYTHOMAS1
How do you release the tension on the timing belt so that it can be replaced? (3 cylinder motor)
Where are the valve timing marks?
what motor???
there is a tensioner that you lossen the center nut, release the tension and tighten it up in the released position for re installing.
