I need to find out where the left side of the crankshaft sensor that. I found the right side put one in?
Wednesday, March 5th, 2014 AT 3:58 PM
KNOWLEDGE IS POWER
MECHANIC
The crankshaft sensor is located at the rear of the engine on the left side here is a guide to help walk you through the repair with the location of the sensor for your car below.
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, March 5th, 2014 AT 4:26 PM
ELKCO
MEMBER
1 POST
2008 CHEVROLET HHR
76,000 MILES
Where is it located at on this engine 2.2, I can't find it
Saturday, November 28th, 2020 AT 4:28 PM
(Merged)
HMAC300
MECHANIC
It's item 4 in pic have you scanned for codes to see if it's bad? Have you check fuel pressure. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
2CP-ARCHIVES
MEMBER
2008 CHEVROLET HHR
100,000 MILES
How do I replace the crank sensor?
Where is the crank sensor located?
If my car needs to be jump started everyone to turn it on what does that mean?
(Merged)
RACEFAN966
MECHANIC
So the car will start and run if you jump start it? If that is the case then don't replace the sensors that won't fix it. I would go my local parts store and have them check the battery, alternater and starter. Most parts stores can do this and most do it for free to. Get back to me and we will go from there.
SPONSORED LINKS
(Merged)
WRENCHTECH
MECHANIC
It certainly doesn't mean you need a crank sensor. Try the obvious. Have the battery and charging system tested.
