2008 Citroen C2 Repair Question
Asked on April 3, 2010
2008 Citroen C2 Air Con Failure
Air Conditioning problem
2008 Citroen C2 4 cyl Two Wheel Drive Manual 12000 miles
The air con makes a whistling noise when turned on and does not cool the air. All the fans work and the LDC indicated that everything is functioning. When on 'auto' the fan increases as the temperature setting is lowered but the air in the vents does not come out cool.
Answer
Replied on April 10, 2010
have the A/C gas (freon) checked/replaced
