Where is the crank sensor on Chrysler town & country with a 3.8 L engine
Monday, January 14th, 2013 AT 4:21 AM
CARADIODOC
MECHANIC
Driver's side, rear of the transmission bell housing, right next to and below the rear cylinder head. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
Tuesday, September 25th, 2018 AT 6:18 PM
2CP-ARCHIVES
MEMBER
2003 CHRYSLER TOWN AND COUNTRY
176,000 MILES
I need to find the crankshaft position sensor. I have the diagram form alldata and have used numerous descriptions from answers I have found on the internet. I am looking on the drivers side where the bell housing meets the block. It is not there!
Sunday, December 13th, 2020 AT 10:12 AM
(Merged)
MECHANIC
Yes it is. It is held by a single 10mm bolt. If you look through the top of the left front tire you can see it there
(Merged)
TODDSMITH1
MEMBER
I found it. Thanks. Now I just have to figure out how to get if off
(Merged)
MECHANIC
You need 2 universal joints on your elbow, lol
SPONSORED LINKS
(Merged)
TODDSMITH1
MEMBER
I took the battery tray out and it was a whole lot easier.
(Merged)
2CP-ARCHIVES
MEMBER
2002 CHRYSLER TOWN AND COUNTRY
196,000 MILES
What's the easiest way to get crank sensor out of 3.3 engine from top or bottom
(Merged)
MECHANIC
Top. It is tight but easier than the bottom
(Merged)
CARADIODOC
MECHANIC
Top driver's side.
(Merged)
CKMIS007
MEMBER
Electrical problem
Car will crank but not start. Trouble code 0320 shows which per my research is Crankshaft position sensor. Have auto manual, but cannot find where sensor is located for this year vehicle by pictures-only says that it is at the back of the trans axle. I have a 3.8L. Can anyone tell me how to find it and what it looks like? I looked up the replacement part at a parts store, but do not recognize it on the engine.
(Merged)
MERLIN2021
MECHANIC
Crankshaft sensor is located on the transmission bell housing (Where engine/trans meet) underneath exhaust crossover pipe.
See the diagram below for location
(Merged)
CKMIS007
MEMBER
Found it! Thanks! Turns out it was the wiring on the plug that the sensor plugs into. Drove it wednesday-squirrels chewed it through wed. Night. Never saw anything like that.
SPONSORED LINKS
(Merged)
MERLIN2021
MECHANIC
Nuts!
(Merged)
INDUSTRIALISTA
MEMBER
Where is the BWD Engine Crankshaft Position Sensor on 2002 Chrysler Town & Country? Some pic or map
(Merged)
MECHANIC
I need the engine size. Also, I can get the position of the crank shaft position sensor, but what do you mean by BWD?
(Merged)
INDUSTRIALISTA
MEMBER
BWD! Does not mean, that is just the name of the sensor as found in the auto part store. 2002 Chrysler Town & Country ENGINE 3.3
I've seen some photos where is the sensor position, but I can not identify it in my car, so if you know where this sensor, please be explicit everything you can because I'm no expert
(Merged)
MECHANIC
Okay, I'll do my best. The sensor is located on the top of the transmission housing. It is near the corner of the rear exhaust manifold manifold. When you open the hood of the vehicle and are standing at the front of it, the transmission and transmission housing will be closer to the right side of the compartment. It is where the trans and engine are bolted together. I have attached a picture to help.
(Merged)
BLBAIN
MEMBER
2001 CHRYSLER TOWN AND COUNTRY
6 CYL
FWD
AUTOMATIC
120,000 MILES
Greetings. I have a 2001 T&C. I was driving it a few days ago and it just shut off. It cranks strong but doesn't fire at all. I have verified that it is pumping fuel. I used a spark plug tester to determine I am not getting spark. OBD II Codes are P0442, P0118, P0123, P00455, & P1193. I have researched these codes as best I could but none of them seem to indicate anything that would prevent a start. I have been told to check the Crankshaft sensor but the description in the Chilton's manual is so vague I can't actually find the dang thing. It has also been suggested that it might be the PCM. Is there any way to test the PCM independently? Any help would be greatly appreciated. Thanks.
(Merged)
DOCFIXIT
MECHANIC
Hi
This should be good lots of codes. Three of the five all point to possible PCM fault. So need some info locate the ECT will be in intake near thermostat housing. Measure voltage on violet/orange wire? Then post. Crankshaft sensor right side engine below exhaust manifold about middle block. Need to get at underneath.
Let me know
Thanks for donate
If Chilton can show you 5volt PCM reference check voltage on TPS and Inlet air temp sensor
(Merged)
BLBAIN
MEMBER
Okay, well, finally, after some additional experimentation and testing we determined to replace the PCM. Got a used one and installed it and the van fires right up. Now, it only runs for about two seconds and then turns off. It will start right back up again, run for about two seconds, and switch off. I suspect that this is actually something to do with the smart key tech but if I have to tow the van to a dealer (25 miles away) and then pay to have everything reprogrammed that is going to have to wait until I can afford it. Am I on the right track here? Any money saving tips? Thanks for your help.
