Radiator Fan Relay
2000 CHRYSLER TOWN AND COUNTRY
RJOHNSON777
Engine Cooling problem 4 cyl Two Wheel Drive Automatic
Yesterday my engine light came on our 2000 minivan, 3.3 engine. We got a code of P1491 indicating a radiator fan relay circuit condition. The car overheated as a result on the wife's return home from work. She turned on the heat and the overheating was abated temporarily. Where can we start to check for the problem? I checked the relays and fuses near the battery and there is no fan relay circuit. I see a blower motor relay. I also see a "rad fan" 40v fuse which looks difference from the rest of the 40's. Where is the radiator fan relay located in the mini-van? Your assistance is greatly appreciated. Ron N. Johnson,
Jul 25, 2009 at 11:54 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
The radiator fan control relay is solid start and is located down on the core support near the radiator on the drivers side. Here are some diagram so you can see for yourself. (Below)
Cheers, Ken
Oct 12, 2017 at 8:05 PM
DONALD HARDIN
nothing yet. Don't know where it is located??
Oct 12, 2017 at 8:05 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
THIS IS A "LX"
IF THESE ARE WRONG, LET ME KNOW WHAT MODEL YOU DO HAVE AND I'LL TRY AGAIN
RETURN WITH A SMILE
THE MEDIC
HERN51
2000 Chrysler Town and Country 4 cyl Front Wheel Drive Automatic 125000 miles
Is there such an item as a low speed radiator fan relay and if so 1. Is it isolated from the fan itself?
2. Where is it located?
Thank You
  • 110,190 POSTS
I never heard of one. The fans run at one speed when they are on.
REEPSX7
Electrical problem
2000 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 122268 miles
My Radiator cooling fans stay on, even when the ignition is off. We put a diagnostic scanner on the vehical and recieved a DTC P1491 "Fan Relay Circuit Fault"
I can't locate the "Relay" for the Radiator cooling fans
Does anyone know where it would be...
Thanks In Advance
Reepsx7
WRENCHTECH
  • 20,761 POSTS
This is not your normal relay. It is a solid state relay and it's mounted to the inside of the frame in the front driver's side, near the radiator.
https://images.2carpros.com/forum/automotive_pictures/561653_Cooling_fan_relay_00_T_and_C_1.jpg
EMAN
Is there any pictures/diagrams of the location of the radiator fan relay on my 2001 Chrysler Town & Country Limited 3.8 liter van?? Or explain in detail how to get to it. I can not find it!!!! HELP!!
SATURNTECH9
  • 30,869 POSTS
It's behind the grill i posted a diagram to show you where it is.
RONCFAIR
2001 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 88,000 miles
Oct 12, 2017 at 8:06 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Coolant fan relay is located behind the grille on front bumper reinforcement
JSGGIB88
1998 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
the radiator fan relay is not working but i can not locate it to replace it any idea where it might be hiding
See location below:
https://images.2carpros.com/forum/automotive_pictures/12900_r_3.gif
