P0700 for transmission control
2003 CHRYSLER TOWN AND COUNTRY
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALFRED BATES
I got a trouble code P0700 for transmission control system malfunction. I would like to know what parts need replacing or what repair procedure I should follow to correct this.
Sep 27, 2009 at 9:06 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
DTC P0700 : EATX Conroller DTC Present
This DTC is simply an indicator that a transmission DTC has previously been set.
A DTC was registered in the transmission control module (TCM). Using the DRBIII(R) scan tool, go to the TCM and read codes.
You will need to have vehicle's TCM scanned at shop with the appropriate scan tool mentioned above.
Sep 27, 2009 at 9:59 PM
BADBRONCO
  • 11 POSTS
I used my wife's van yesterday and it was fine. This morning, it's broken. Obviously, I'm suspect since I was the last to use it ... lol but I've been trying to get some info and thought you guys could help. Here are the specs
Here's what's happening - Wife went to drive it this morning. It was 'bucking' during downshifting only into 2nd and 1st gear. No issues accellerating. She brought it back, and it was low on fluid. I topped it off. Fluid didn't appear burned or red/brown. Still Bright. I drove it around, and felt the bucking. While driving it all the sudden lost all gears but 2nd (limp mode) but after shutting it off, I had the gears all back (out of limp mode) but it was bucking downshifting into 2nd and 1st gear again. Then it went back into limp mode.
Here's what I've done - Pretty much nothing. It's sunday..but... I thought maybe it was bucking because it was low on fluid, and the P0700 code needed to be cleared out. I disconnected the battery for about 30 min, reconnected it, and without even starting it, and just turning the key fwd/back 3 times, the P0700 is there. Didn't even start it.
My question is shouldn't the vehicle need to be driven? I thought that the sensors in the Transmission sent info (above or below spec) to the TCM and it interpreted it and sent to the PCM to put the CIL on or off...or some variation of that. Would the 0700 being there after clearing codes indicate that the TCM is so broken, it's picking it up immediately, without driving it?
I'm a novice, and don't pretend to do the good work you guys do, this is just a product of knowing a LITTLE about cars (hey, I own a 91 Bronco - you tend to learn a little owning that hog) and I've been googling all day.
Any help would be more than appreciated
Feb 4, 2019 at 4:09 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
The TCM go out all the time in these becasue they place them near water I would remove the connector and clean it from corrosion which usually fixes it here is the location in the diagrams below. Check out the diagrams (Below). Please let us know what you find.
BADBRONCO
  • 11 POSTS
Does that need to be taken to a Dealership or Transmission center to do? I'm assuming they would charge for that?
Also, would one of those things cause it normally to give just 1 error code (0700)?
BMRFIXIT
  • 19,053 POSTS
p0700 is just an information code
and it is that TCM have codes and requested check engine light on
most repair shop can help in get the tcm codes
it should points to what is the problem
if to start should do speed sensors 1st
BADBRONCO
  • 11 POSTS
Sorry for the delay in getting back here. Had some personal issues come up and the van had to sit for a while. I did get it up to one of the local transmission shops yesterday...
He said he wasn't getting any codes from the TCM, so he cleared the P700 code, drove it around for 10-15 min and it was fine. He said he felt a slight 'flair' going from 3rd - 4th. He drove it around more and then the vehcile went into limp/safe mode again. He sait it gave a P700 code, and now the TCM is telling him "4th Gear Ratio Error" He said he checked the CVI (Clutch Value Index) data, and it all looked within spec. He said to further diagnose it, he'd need to remove the transmission, crack it open and go through it.
He said he can give me a price once he finds the internal issue. He also said that if he finds the problem, and I don't like the price, he'll put the transmission back together, and in the vehicle for $389.
My question - With ONLY a P700, and nothing else showing, could the issue possibly be an input/output sensor, or would that have shown up in the Van's computer. Is it possible that just having a P700 is not internal? I originally researched and saw the TCM's DO go bad, but he's saying it's fine because he's not getting some BIOS error when reading the codes.
BADBRONCO
  • 11 POSTS
Is there any additional testing I could do? Is there a way to pull the input/output sensors and check with a multimeter, or maybe some of the other sensors that could possibly cause this?
BMRFIXIT
  • 19,053 POSTS
Input and output sensors about $30 and it take about 15 minutes to do
at this point I would take the chance and do it
what was the codes that he pulled from the TCM
BADBRONCO
  • 11 POSTS
he didn't give me any codes (not sure if that was purposely or not). All he told me is that it gave him a "4th gear ratio error"
Kinda baffled at the need to drop a transmission and crack it based on him telling me it drove fine for 15-20 min after he cleared the codes till it threw the 0700 code again, and that everything else seemed to be 'in spec'
Would a sensor necessarily give a PCode? I think I read that there was a PCode associated with a bad input/output sensor....but the odometer never gave anything other than P0700 (and I think an O2 sensor that just went bad)
BMRFIXIT
  • 19,053 POSTS
4th gear ratio incorrect usually end up in tranny need to be rebuilt
give me few minuets I will go to my book and look up code p0700 and post my finding
BMRFIXIT
  • 19,053 POSTS
Dtc p0700: internal trans controller
Note:for circuit, connector and terminal identification and/or component location, see connector identification and/or wiring diagrams .
Circuit description
Dtcs will set if an internal tcm malfunction occurs.
Possible cause
Internal tcm failure.
Diagnostic procedure
Note:ensure pre-diagnostic check has been performed before proceeding with following procedure.
Record all dtcs and one trip failures. Using scan tool, erase dtcs.
Turn ignition from off to on, then start engine.
Apply brakes. Slowly move gearshift lever through each gear position. Check if dtc p0604, p0605 and/or p0700 has reset. If dtc p0604, p0605 and/or p0700 is present, replace tcm.
perform shift quality quick-learn procedure and pinion factor procedure under programming.
If dtc p0604, p0605 and/or p0700 is not present, go to next step.
Inspect the following for pushed out terminals or faulty connections and repair as necessary:
Engine ground connections
Tcm grounds
Tcm battery feed
Tcm fused ignition switch output circuit
Power feed to transmission control relay
If procedure in previous step fails to diagnose problem, erase dtcs using scan tool. Perform ver-1a: verification test . If transaxle is still not functioning correctly, replace tcm. See transmission control module under removal & installation. Perform shift quality quick-learn procedure and pinion factor procedure under programming. If transaxle is functioning correctly, test is complete.
BADBRONCO
  • 11 POSTS
Let me ask you a quesiton about this. Prior to taking it up to them, I had removed the battery cables, and let it sit to clear the code from the car.
Prior to even starting the vehicle, the P0700 had come back.
Would you think the TCM is the likely culprit in that situation?
Previously you mentioned P0700 was informational, but what you posted seems to imply that if you clear the codes, and P0700 comes back (even if it's the only code) then it's a faulty TCM unless I read that wrong.
Is removing the battery cable sufficient enough to clear the P0700 and if so, if it came back without even starting the car, is that normal? I would have thought it would have had to be driven. I've got no way to verify what he claimed (as far as clearing it and then it coming back 15-20 min of driving later). In my driveway, I removed the battery cables, reconnected and it came back.
He did say initially there were no codes in the TCM so he cleared it, and when P0700 came back THEN he saw this "4th gear" code.
Could he be blowing smoke up my TCM maybe?
EDIT - The more I think about it, maybe the P0700 did come back when I started it, but it DEFINITELY came back without me shifting the shift lever or driving it.
BMRFIXIT
  • 19,053 POSTS
The p0700 is an information code for sure
as the book is stating if no other codes then the P0700 in the TCM
suspect bad TCM
if you disconnect the battery that should for sure clear all codes and reset the PCM and the TCM
and if the light came back on upon starting
with the p0700 and no other code TCM is at fault
what I would do since dont have scanner to access the TCM and its codes
check with local repair shop if they can scan it for you and give you the codes
as I sense that you have no trust in what the tranny shop said to you
do clear the codes let them check it 1st
let me know
BADBRONCO
  • 11 POSTS
[quote:9fdc18b1ad="BMRFIXIT"]as the book is stating if no other codes then the P0700 in the TCM [/quote:9fdc18b1ad]
Just to clarify... When you say this, you mean the PCM? I have no way to check the codes in the TCM, only PCM. The first time the guy from the Transmission shop hooked up the computer to the TCM, he told me (when I dropped it off) that there were no codes in the TCM but he'd go through the electrical system. It was in limp mode and driven about 20 minutes to his shop in 2nd gear from when I cleared the codes last.
After he 'cleared the codes' he told me that the PCM 0700 code came back (with 20 minutes of driving), and he checked the TCM code and got the 4th Gear Ratio Error code.
If I get her back from him (Probably Monday) and Unplug the battery for 20 min or so, hook the battery back up, I should check codes (KOEO), then start car (without moving gear shifter) and if the CIL comes on, and the PCM is giving me P0700 without engaging transmission or driving, then it would indicate a bad TCM?
I guess what I'm wondering here is if I clear the codes (disconnecting battery) and start the van and instantly codes come back without moving, is that normal? Shouldn't the car have to be driven, for something to be out of spec or out of range for the TCM to find out and tell the PCM to give a P0700? I was thinking that for the Van to give a P0700 (PCM code) it really would need the TCM to see something was wrong. Can a TCM see something wrong without it even being driven or engaged?
I'm leaning towards the TCM being bad based on the cleared codes coming back the moment the vehicle is started. Is that safe thinking?
I REALLY appreciate all the help. I feel like I'm close to getting this nailed down, I just want to make sure before I drop $200 on a TCM, that my thinking is sound based on how it's supposed to work under normal conditions.
As far as not trusting the guy, I used to be in sales. Very deeply. I just feel like he's pitching, price shielding me, and doing various other sales techniques, and I just want my car fixed, not sold on something.
When he first hooked the computer up, he was pushing buttons and at one point flashed past a screen that I saw the word "CRANK" on it. The screen after that told him the car wasn't in limp mode and he kinda waved it in my face to say "it's not in limp mode, you're actually STUCK in 2nd gear -oooo bad..... When I questioned him on the screen I saw very briefly, he went back, cranked the key forward, redid his test, and all of the sudden it was in limp mode on his computer. His credibility kinda went down hill for me there...also considering the P0700 came back INSTANTLY without driving it in my driveway, where he states he had to drive it for 20 minutes to get it to come back. Just feeling sour about him is all...
BMRFIXIT
  • 19,053 POSTS
I hope to be clear with this one
if have a code in the PCM that is p0700 need to use a scanner and check TCM for codes
an OBDII reader will not get you to the TCM codes
know if in the TCM have NO other codes but the P0700
suspect bad TCM
if have any other codes have to fix them 1st and reset
disconnecting the battery will reset any and all codes
this dude that you dealt with ………(no comment )
best way I would be dealing with this
is like that
check around your local area if any of the repair shops have a scanner (which they all should have if they repair any newer cars )
ask them if they can help you in getting the codes out of the TCM
always check fuses and relays and wiring before replacing any module
BADBRONCO
  • 11 POSTS
Thanks for the clarification.
I have read things that say you CAN clear the codes in a TCM by disconnecting a battery on this make/model and some that say you cannot, and a scan tool must be used to clear the codes...so I wasn't really 100% sure....
My thought was that if you CAN clear both PCM/TCM codes and P0700 is coming back upon starting the vehicle...TCM needs to be replaced
If you cannot clear TCM codes by disconnecting battery, then it's simply coming back on start up because TCM has the original error data and was telling P0700 time to wake up :)
I understand you to say say that the battery will clear PCM (P0700) and the TCM (4th Gear Ratio).
I'm going to see about getting it to another shop next week. I'm not going to say a word about another shop looking at it, and see where it goes from there. I'll ask the first shop for a print out of the codes and see what he says.
I'm just at a loss now as to why 1 time there were no codes in TCM, then when I left, he found em. Maybe I know the answer already thought....
Give me a few days and I'll post what happens next :) THANKS AGAIN!!
SWANM66
Post subject: So What was the fix? Thanks
[quote:59e2188463="badbronco"]Thanks for the clarification.
Give me a few days and I'll post what happens next :) THANKS AGAIN!![/quote:59e2188463]
BADBRONCO
  • 11 POSTS
I ended up removing the connector which I should have done early, cleaned the connection which had rust all fixed!
PATSY WILEY
I fixed my error code in 1 hour it's very simple all I did was call a junkyard to buy a transmission control module tmc just jack up the van on the driver side front wheel to change the tmc it's very easy the module costs was 75.00 bucks my check engine light went off without any problem you can reset it by turning the key on and off till the computer resets drive Van problem is solved my error code was 0605/0700
AMTRACKER
  • 13 POSTS
'97 T&C giving me a P0700 code. reported loss of drive while driving. it came back after it sat. any ideas, control moduale or something?
CARADIODOC
  • 34,309 POSTS
That just means there is a diagnostic fault code in the Transmission Computer and the transmission is in "limp-in" mode where it stays in second gear so you can drive it slowly to a repair shop without needing a tow truck. Having the code(s) read by a mechanic with a scanner that can access the Transmission Computer is the place to start. The codes will point to the circuit or system with the problem, not necessarily a defective part.
PROTECH1980
  • 901 POSTS
Most common problem associated with this code are either for a failing input or output speed sensors, You could ohm the sensors, A good sensor should measure less than 800 ohms.
PROTECH1980
  • 901 POSTS
Sorry caradiodoc, didnt see you posted
AMTRACKER
  • 13 POSTS
thanks guys. is there a way for me to see codes on that system with my OBDII?
CARADIODOC
  • 34,309 POSTS
Don't apologize PROTECH1980. Everyone is posting over everyone else since we lost the ability to delete our own replies. Two heads are always better than, . . . mine! Your code reader will only read codes from the Engine Computer. You need a professional scanner to read codes from the EATX. That's the Electronic Automatic Transmission Controller, a fancy name for the Transmission Computer. It told the Engine Computer to turn on the Check Engine light because that is required when the code is related to something that could cause an increase in tail pipe emissions.
AMTRACKER
  • 13 POSTS
ok, so I replaced the input and output speed sensors.........when i pulled one out........(wait for it)........there was a tree of metal fillings stuck to it! Think its terminal?(sarcasm)
CARADIODOC
  • 34,309 POSTS
What happened when you cleaned him up? Some trucks have similar problems with the rear-wheel anti-lock speed sensors in the differential housing that also grow fuzz and stop developing signals. I'm bettin' yours will work after you clean it.
AMTRACKER
  • 13 POSTS
I didnt clean it up. I replaced it and cleared the code. Then test drove it and got the same reaction, limp-in mode and only 30 miles an hour
Feb 4, 2019 at 4:10 PM (Merged)
AMTRACKER
  • 13 POSTS
This wasnt fuzz. It was a TREE of large metal shavings. I am pretty convinced that it is dead in the water. I plan to rebuild and sell the tranny and engine to recoop my loses.
MARK CRANE
P0700 code: My 2005 Town and Country wouldn't shift in hot weather after driving a while, so I went into the fuse box and replaced the EATX Safety Shut Down Relay for $20.00. Problem solved! Thanks, Occam's razor!
Aug 15, 2020 at 8:09 AM
I am sure that will help others in the future. Please come back if you have other issues and need help. Thanks for visiting 2CarPros.
Aug 15, 2020 at 8:31 AM
