Where is the crank sensor?
2004 CHRYSLER TOWN AND COUNTRY
140,000 MILES
ANONYMOUS
Where is the crank sensor on Chrysler town & country with a 3.8 L engine
Jan 14, 2013 at 4:21 AM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
Driver's side, rear of the transmission bell housing, right next to and below the rear cylinder head. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 25, 2018 at 6:18 PM
2CP-ARCHIVES
  • 4,540 POSTS
I need to find the crankshaft position sensor. I have the diagram form alldata and have used numerous descriptions from answers I have found on the internet. I am looking on the drivers side where the bell housing meets the block. It is not there!
Dec 13, 2020 at 10:12 AM (Merged)
yes it is. it is held by a single 10mm bolt. if you look through the top of the left front tire you can see it there
TODDSMITH1
I found it. Thanks. Now I just have to figure out how to get if off
you need 2 universal joints on your elbow,,,lol
TODDSMITH1
I took the battery tray out and it was a whole lot easier.
2CP-ARCHIVES
  • 4,540 POSTS
What's the easiest way to get crank sensor out of 3.3 engine from top or bottom
top. it is tight but easier than the bottom
CARADIODOC
  • 34,309 POSTS
Top driver's side.
CKMIS007
Electrical problem
Car will crank but not start. Trouble code 0320 shows which per my research is Crankshaft position sensor. Have auto manual, but cannot find where sensor is located for this year vehicle by pictures-only says that it is at the back of the trans axle. I have a 3.8L. Can anyone tell me how to find it and what it looks like? I looked up the replacement part at a parts store, but do not recognize it on the engine.
MERLIN2021
  • 17,250 POSTS
Crankshaft sensor is located on the transmission bell housing (Where engine/trans meet) underneath exhaust crossover pipe.
See the diagram below for location
CKMIS007
found it! thanks! turns out it was the wiring on the plug that the sensor plugs into. drove it wednesday-squirrels chewed it through wed. night. Never saw anything like that.
MERLIN2021
  • 17,250 POSTS
Nuts!
INDUSTRIALISTA
Where is the BWD Engine Crankshaft Position Sensor on 2002 Chrysler Town & Country????? some pic or map
  • 110,190 POSTS
I need the engine size. Also, I can get the position of the crank shaft position sensor, but what do you mean by BWD?
INDUSTRIALISTA
BWD!!! does not mean, that is just the name of the sensor as found in the auto part store........ 2002 Chrysler Town & Country ENGINE 3.3
I've seen some photos where is the sensor position, but I can not identify it in my car, so if you know where this sensor, please be explicit everything you can because I'm no expert
  • 110,190 POSTS
Okay, I'll do my best. The sensor is located on the top of the transmission housing. It is near the corner of the rear exhaust manifold manifold. When you open the hood of the vehicle and are standing at the front of it, the transmission and transmission housing will be closer to the right side of the compartment. It is where the trans and engine are bolted together. I have attached a picture to help.
BLBAIN
Greetings. I have a 2001 T&C. I was driving it a few days ago and it just shut off. It cranks strong but doesn't fire at all. I have verified that it is pumping fuel. I used a spark plug tester to determine I am not getting spark. OBD II Codes are P0442, P0118, P0123, P00455, & P1193. I have researched these codes as best I could but none of them seem to indicate anything that would prevent a start. I have been told to check the Crankshaft sensor but the description in the Chilton's manual is so vague I can't actually find the dang thing. It has also been suggested that it might be the PCM. Is there any way to test the PCM independently? Any help would be greatly appreciated. Thanks.
DOCFIXIT
  • 18,828 POSTS
Hi
This should be good lots of codes. Three of the five all point to possible PCM fault. So need some info locate the ECT will be in intake near thermostat housing. Measure voltage on violet/orange wire? Then post. Crankshaft sensor right side engine below exhaust manifold about middle block. Need to get at underneath.
Let me know
Thanks for donate
If Chilton can show you 5volt PCM reference check voltage on TPS and Inlet air temp sensor
BLBAIN
Okay, well, finally, after some additional experimentation and testing we determined to replace the PCM. Got a used one and installed it and the van fires right up. Now, it only runs for about two seconds and then turns off. It will start right back up again, run for about two seconds, and switch off. I suspect that this is actually something to do with the smart key tech but if I have to tow the van to a dealer (25 miles away) and then pay to have everything reprogrammed that is going to have to wait until I can afford it. Am I on the right track here? Any money saving tips? Thanks for your help.
[quote:46f3c0cc0b="Docfixit"]Hi
Let me know
Thanks for donate
If Chilton can show you 5volt PCM reference check voltage on TPS and Inlet air temp sensor[/quote:46f3c0cc0b]
DOCFIXIT
  • 18,828 POSTS
The PCM needs to be programed and SKIM secret key data must be programed for vehicle to run. Sorry don't have any money saving tips.
GILLYS
HI
I own a 2001 t&c lxi with 150000 miles.
a few days ago it just would not fire.
we tried replaceing coil and the crank shaft, no fire.
fuel flows, electric is fine.
some guy ran hooked it up and got some codes(i don't know which).
he says i need to replace the bcm(body control module).
another shop took their chances or "my chances" i should say, and claims i need a pcm not a bcm.
i am realy hoping this could be done without spending a furtone.
i was wondering how did it work out for you, it seems you had a similar problem.
thank you very much for sharing your experience.
pinny
[quote:2bcbf195bd="blbain"]Okay, well, finally, after some additional experimentation and testing we determined to replace the PCM. Got a used one and installed it and the van fires right up. Now, it only runs for about two seconds and then turns off. It will start right back up again, run for about two seconds, and switch off. I suspect that this is actually something to do with the smart key tech but if I have to tow the van to a dealer (25 miles away) and then pay to have everything reprogrammed that is going to have to wait until I can afford it. Am I on the right track here? Any money saving tips? Thanks for your help.
[quote:2bcbf195bd="Docfixit"]Hi
Let me know
Thanks for donate
If Chilton can show you 5volt PCM reference check voltage on TPS and Inlet air temp sensor[/quote:2bcbf195bd][/quote:2bcbf195bd]
DAMON G
  • 6 POSTS
My crankshaft sensor broke off bad and will not move if I knock it in and retrieve it what pan will I drop transmission or oil need help.
Dec 13, 2020 at 10:13 AM (Merged)
Hi Damon,
I would not try to knock this through. First of all, I doubt it will actually go through because the sensor sits just over a tone wheel and if you even get it through there then you will more than likely damage this tone wheel and then you will be removing the transmission to replace it.
This sits in the bell housing of the transmission and as I said, if it goes through it will not just fall into the oil pan because it is on the top of the transmission and there is not enough clearance between the case and the components inside for it to fall.
I am not sure the best way to get it out but knocking it in will almost guarantee you removing and disassembling the transmission.
Can you get a picture of what it looks like so I can see what we are dealing with and I will see if I have any ideas? Thanks
DAMON G
  • 6 POSTS
I have two screws in it and still will not move. thanks for that information.
Holy cow. What is the black around the sensor and on the case? Is that from a torch? If so, the plastic may be melted to the case which is why it is so hard to get out.
I would suggest drilling it out if you can get a drill down there. If not, what you are doing is the best way. Are you trying to put a set of pliers on those two screws and turn it like a screw to break it loose?
If that is just dirt and grime then I would try to soak it in some sort or penetrating oil to try and free some of it up.
Worst case just use a larger and larger screw. Do you have room to get a small slide hammer in there? They have some with a vice grip attachment so you can put it an angle.
Let me know what you have tried and if none of this works and we can go deeper.
THEREDNEXK
On a 2008 Chrysler town and country touring 3.8 can I remove the coil pack and get to the crankshaft position sensor?
Sep 5, 2024 at 8:34 AM
  • 54,354 POSTS
Here is the location of the crankshaft position sensor and how to change it out. Check out the images (below). Let us know if you need anything else.
Sep 5, 2024 at 8:48 AM
