Location of the speed sensor
RUGDAT
  • 2002 CHRYSLER TOWN AND COUNTRY
Electrical problem6 cyl Two Wheel Drive Automatic 105000 miles
Odometer works but speed indicator does not. Have a replacement part for the output speed sensor. Where is it located?
Saturday, November 14th, 2009 AT 9:24 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
There are two output speed sensors one is for the transmission and the other is for the computer. Here are both locations. (below)
https://www.2carpros.com/forum/automotive_pictures/188069_02tandcspeedsen_1.jpg
Larger images below
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Tuesday, October 17th, 2017 AT 6:46 PM
BLACKOP555
  • 10,371 POSTS
It is located on the transmision.
Try to find it. If you cant find it get back to me on here or my email and I can find a diagram for it or show you a picture of the vss.
Tuesday, October 17th, 2017 AT 6:47 PM (Merged)
BESTWON
Inside the transmission or where on the transmission I have spent all day looking on the housing but stilll cannot locate
BLACKOP555
  • 10,371 POSTS
First do you kn ow what your looking for? have you went to a part store or looked online for a vss to see what to look for?
second i will assume you have the LX model so this information will be for a lx, you can post back what you have so i can find a proper one but all three should be very similar.
a 2.4l the sensor is located on the left rear of the engine. diagram below.
https://www.2carpros.com/forum/automotive_pictures/66751_Graphic1_1.jpg
3.0l is on the left rear of the engine, see diagram bellow.
https://www.2carpros.com/forum/automotive_pictures/66751_Graphic2_1.jpg
those pictures took a while to find.
CAROLINA GODINEZ
  • 1999 CHRYSLER TOWN AND COUNTRY
  • V8
  • 18,000 MILES
Computer problem
1999 Chrysler Town and Country V8 Two Wheel Drive Automatic 180, 00 miles
WHERE IS THE VEHICLE SPEED SENOR LOCATED? I BELIEVE THIS IS WHATS WRONG WITH MY VAN, BUT I CANT FIND THE VSS TO REPLACE IT. DOES MY VAN HAVE A VSS? WHERE IS IT? DO U HAVE A DIAGRAM TO LEAD ME TO IT. THANKS
LEGITIMATE007
  • 5,121 POSTS
This vehicle doesnt make a v-8, but that doesnt matter. The vehicle speed sensor is located on the transmission, it has a harness plugged to it
RUBEN ROBLES
I got same problem and no one don't know WHERE is the VSS in the transmission. Every one said is in the transmission, but where? I found the in and out sensor solenoid and I do not found the vehicle speed sensor. Is located on transmission and has a harness plugged to it. OK? WHERE am found that? Close to What?
JOSHTRIED
  • 1997 CHRYSLER TOWN AND COUNTRY
Transmission problem
1997 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
im trying to locate the current vehicle speed sensor and transmission speed sensor. I have a 3 speed. I have a manual from autozone, but it only shows 4 speed
  • 108,262 POSTS
Hi:
If never heard of a three speed in a 1997. Is it possible someonw may have replaced the transmission with one from a different year?
