Wiper motor replacement
2010 CHRYSLER TOWN AND COUNTRY
JOHNSHAD29
I need to replace the wiper motor can you please help me?
Nov 11, 2012 at 7:29 PM
  • CAR REPAIR CONTRIBUTOR
Here are the instruction in the diagrams below to show you how to replace the wiper motor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 11, 2012 at 8:23 PM
PAXDEANTHRO
2000 Chrysler Town and Country
I just replace the windshield wiper motor in my van and now the wipers are at rest in the up position. Based on other posts, it looks like I might need a different motor. Is this true, or is there another problem?
May 20, 2020 at 1:27 PM (Merged)
  • 110,190 POSTS
Hi:
The motor determines where the wipers park. If they are doing what you described, that is where the problem lies.
RHIANNACP
I think my windshield wiper motor might be going out. Whenever I turn the wipers on they go up but get stuck going back down and i hear a loud whining noise. Not having any other issues with the vehicle besides this. Could it be the wiper motor?
  • 110,190 POSTS
Will they come back down on their own eventually, or not? Also, you mentioned that you hear the motor running, have you checked the linkage to the wipers?
ROBERT MCCARTHY
no power going to wiper motor checked fuse and relays check out good changed motor still does not work
MERLIN2021
  • 17,250 POSTS
FRONT WIPER/WASHER SWITCH NOTE: Wiper/washer switch is part of multifunction steering column switch. If wiper/washer switch fails, entire multifunction switch must be replaced. Disconnect wiper/washer switch connector. Using ohmmeter, test for continuity between switch terminals with switch position as indicated. See WIPER/WASHER SWITCH CONTINUITY TEST table. See Fig. 2 . If continuity is not as specified, replace multifunction switch.
https://images.2carpros.com/forum/automotive_pictures/62217_CTCb_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_CTCa_1.jpg
CARADIODOC
  • 34,309 POSTS
Very common problem is a defective body computer. Not sure why they had to computerize a wiper system, but it's one of the reasons people don't want to buy new cars. I've known a few people who just ran a wire from a toggle switch on the dash board to the wiper motor and forgot about the delay function. Cheap "fix" for an expensive, unreliable computer.
caradiodoc
