Transmission problem
1993 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
I took it to a mechanic and they scanned it and only told me that the temp sensor had a code. It is an overdrive trans with a 3.3l eng. While driving at highway speeds it is shifting into low. My son is checking it out now and says he needs a scan tool but he can't find one to work on it. We replaced the selinoid pack and no luck he said he will pull the valve body to check it and clean it and he has been advised that it might be the electronic preasure sensor.
Mar 9, 2010 at 2:43 PM
