Low beams do not work, changed bulbs, new fuses new switch, #31 fuse no power high beams and parking lights work?
Sunday, October 21st, 2012 AT 3:16 PM
SATURNTECH9
MECHANIC
Have you checked to see what your missing at the low beam connector with the low beams on power or ground. I would check the fuses and if okay it sounds like the TIPM is out which is common here are the headlight wiring diagrams and the TIPM module replaced guide which is easy because it self initializes. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, October 21st, 2012 AT 3:33 PM
SHANNON_PRIV
MEMBER
1 POST
Thank you for this psot I had this problem and had to get a new TIPM for $230. All fixed! I love this site.
Saturday, August 3rd, 2019 AT 1:08 PM
BUSTER10
MEMBER
2004 CHRYSLER PT CRUISER
4 CYL
FWD
AUTOMATIC
114,000 MILES
The other day I tried to turn my head lights on and they would not come on but as I were riding along the street I hit a bump in the road and my front head light came on. So what do you think the problem could be and also my new keyless remote will not work ethier
(Merged)
DOCFIXIT
MECHANIC
Hi buster10
The headlight thing maybe the headlight relay in engine compartment. The bump probably caused relay to close. Try tapping it next time lights don't come on. If so replace.
The keyless entry you said new as in new transmitter? If so did you program? Do you have another one you could try?
Let me know
Thanks for donation
(Merged)
BUSTER10
MEMBER
Do you think the problem with my headlights is that I need a headlight switch that I use to turn my head lights on with. Because my fog lights are also on the switch and they will not work either
SPONSORED LINKS
(Merged)
SHEILAJO
MEMBER
1 POST
My passenger headlight went out and I had a guy replace it, now it wont work. Ive tried several headlights none of which wouldnt work. Then I got one to work on high beans only. Ive checked fuses, wiresrelays', couldnt find anything so what do u reconmand/.
(Merged)
HMAC300
MECHANIC
Check fuse 16/17 under hood for headlights, then checkgrounds on rh fender and lh strut see if they are making good contact and not loose. It may be multifunction switch in steering column as well
