2005 Chrysler Pacifica Repair Question
Topics covered: Air filter, Door, Door latch.
Asked on May 12, 2009
2005 Chrysler Pacifica LOCATION OF CABIN AIR FILTER
Air Conditioning problem
2005 Chrysler Pacifica 6 cyl Front Wheel Drive Automatic 70000 miles
My vehicle's manual indicates that the cabin air filter is located under the glove compartment. I tried to replace the filter but I can't find it. Can you please help me locate the cabin air filter of my vehicle?
Answer
Replied on May 12, 2009
Locate the air filter door on the bottom of the lower evaporator housing just outboard of the passenger side of the instrument panel center stack. See Fig.
Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the door.
Pull the air filter door straight downward to disengage it from the air filter opening of the lower HVAC housing.
Use your fingers to reach through the air filter opening of the HVAC housing far enough to grasp the air filter.
Pull the air filter straight down and out of the HVAC housing and remove it from the vehicle.
