1994 Chrysler New Yorker Car turns over but won't start
1994 CHRYSLER NEW YORKER
20,700 MILES • 6 CYL • FWD • AUTOMATIC
THAKABU
My car turns over but will not start,I put a new fuelpump on,that was'nt it,I changed the fuelpump relay that was'nt it,I also checked the fuel pump fuse that was'nt it,so,we checked to see if we were getting fire and fuel we were getting neither,we changed the crankshaft sensor, we got fuel pressure but it would not start,finally we changed the camshaft sensor and it started for about 1 minute the it quit,it started again for about 30 seconds then it quit and started doing the same thing,I the replaced the computer with a used one with the same serial number and still had nothing, I then put the old original computer back in still no fire, but, we took the cap off the relay fuse and squeezed the little connectors together and fuel shot out each time from the pressure line, could you let me know if there is any thing else we could try? Perhaps both computers are bad and it might require a new one, But I would like to exhaust all of my options before I spend major money on a diagnostic and repair bill I also had the ignition coil tested and the guy said it was good enough to start the car.
Mar 15, 2009 at 8:45 PM
