1996 Chrysler LHS Repair Question
Topics covered: Blower motor, Panel, Control panel.
Asked on October 6, 2010
1996 Chrysler LHS blower motor resistor
Heater problem
1996 Chrysler LHS 6 cyl Two Wheel Drive Automatic 212xxx miles
if the blower motor resistor go bad will it make the blower not stop and the controle pan stop working
Answer
Replied on October 6, 2010
Do you have an auto temp control system?
Do you just dial in a temp and the blower changes speeds automatically?
yes its a turn one but the contro panel dont work or show display and i have to take out the fuse to make the blower motor stop when im driven it stays on intill you turn off the car the guy i got the car from sayed it just stop one day
If the control panel is not responsive, then that has to be replaced first and then see if you still have an issue. There isn't much question that is bad.
if that is not what it is then what do you thank it could pe
