How to change a battery?
JOE SMITH
  • 2004 CHRYSLER CONCORDE
  • 118,000 MILES
Slow to turn over I need a new battery please help me change it
Saturday, November 5th, 2011 AT 12:53 AM
BILLYMAC
  • 2,204 POSTS
Remove the batt hold down remove the cables pull battery out replace the cables tighten them reinstall the hold down. you should use a memory saver to hold all of your settings like radio stations climate. This guide can help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
REMOVAL
The battery is accessible without removing the right front wheel and tire assembly.
1. Verify that the ignition switch and all accessories are OFF.
2. Turn the steering wheel to the full right position.
3. Disconnect and isolate the negative battery cable remote terminal from the remote battery post.
WARNING: NEVER GET UNDER A LIFTED VEHICLE IF NOT SUPPORTED PROPERLY ON SAFETY STANDS.
4. Remove the air cleaner housing. Refer to the index for the location of the procedure.
5. Remove battery splash shield. Refer to the Body section of the service for the procedure.
6. Disconnect the heater blanket cord, if equipped.
7. Remove the two short bolts from the battery hold down and remove the hold down.
8. Disconnect the positive battery cable from the battery.
9. Slide the battery toward rear of vehicle.
10. Disconnect the negative battery cable from the battery.
11. Remove battery from vehicle.
INSTALLATION
1. Position the battery in the battery tray.
2. Connect the positive and negative battery cables. Torque to 16 Nm (150 in. lbs.).
3. Connect the heater blanket cord, if equipped.
4. Install the battery hold down and install the hold down bolt. Torque to 16 Nm (150 in. lbs.).
5. Install battery splash shield. Refer to the Body section for the procedure.
6. Install the air cleaner housing.
7. Connect the negative battery cable.
Saturday, November 5th, 2011 AT 12:59 AM
DADSBROWNING
  • 6 CYL
  • FWD
  • 75,000 MILES
How do I replace a battery on a 2004 concord? I have the air filter box out, now what?
Wednesday, November 25th, 2020 AT 8:42 AM (Merged)
  • 108,348 POSTS
Is this one under the hood or in the fender well?
DADSBROWNING
This battery is somewhat under the headlight on the passenger side and under the air filter box.
JONZEE222
  • 7 POSTS
You need to take the front passenger wheel off and then remove the 'door' on the front of the wheel well.
2CP-ARCHIVES
  • 4,540 POSTS
  • 1999 CHRYSLER CONCORDE
  • 175,000 MILES
How do I replace a battery on a 1999 Chrysler Concorde 3.2 Liter engine?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,262 POSTS
This guide will give you the idea on how to change the battery in your car
Turn the steering wheel all the way to the right.
Negative Battery Cable Remote Terminal
Remove air cleaner housing.
Remove two short bolts to battery hold down.
Slide battery rearward to disconnect the negative and positive battery terminals from battery.
Slide battery toward rear of vehicle and lift out through wheel well opening.
Cheers, Ken
DGAMBOA150
  • 1998 CHRYSLER CONCORDE
My car doen't start it makes clicking sounds I don't know if it flooded or I need to change the battery. I just replaced my sensors.
ZACKMAN
  • 4,202 POSTS
Take the battery out the car, and have it tested at a parts store. Most of them will do it for free. Also check both terminals, make sure that they are free of corrosion and are tight.
