Radio not working
MY2SONS
  • 2010 CHRYSLER 300
  • 0.6L
  • 6 CYL
  • 4WD
  • 65,000 MILES
It won't come on
Sunday, November 15th, 2015 AT 11:50 AM
  • 31,937 POSTS
Check for blown radio fuse in fuse block, if that is ok remove radio and check that there is power up to the unit, no power there back check through loom to known power for break or fault in plug, if power at unit plug, check for fuse on back of unit or have unit bench tested for internal faults.
Monday, February 27th, 2017 AT 2:13 PM
MY2SONS
I installed a new radio and satellite unit and the system works again! Thanks you guys.
  • 31,937 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
MOMKWAT
  • 2004 CHRYSLER 300
  • 70,000 MILES
My radio and navigation screen will not light up. The music plays but cant change any channels. The cd will only play if I eject a cd and reinsert it so that it defaults to playing a cd.
Cannot change any channels or tracks. The steering wheel buttons for volume work but the one on the left side to change the radio to cd, or satellite etc does not work.
Please advise. Are there fuses related to this problem.
It just started this morning - nothing happened out of the ordinary - just started car and found out.
The next time I got in the car, it just worked. Most the time it works and I have had about two times where it was not working.
Other weird things are happening - I noticed that the security light was flashing really fast one night instead of the regular blinking.
Maybe I have some sort of electrical thing that happens once in a while.
Might want to notice if you are having other issues. My car does seem to have them.
Monday, January 6th, 2020 AT 12:56 PM (Merged)
BRADYBEREK
Hi! I have the EXACT problem with my radio. I do hope we find a solution. It's been happening to me daily since its gotten cold out-nearly zero here. Someone posted on another site that he suspects my nav is going out and I may need a new radio unit. I'd like to know for sure.
I also have another odd electrical issue like you, but mine us with my wipers. The intermittent is random. The blades will swipe normally, then nothing for about 5 cycles then its line it plays catchup and swipes 5-7 in a row then stops in the middle of the windshield.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,967 POSTS
It sounds like the satellite receive module is bad because the problem you have described is internal tied to the radio.
Here is a guide to help you remove it then I would try to find a used one.
Please let us know what you find out so it will help others
Best, Ken
TODO
  • 1999 CHRYSLER 300
1999 Chrysler 300
The radio does not work in the 1999 300 is that something major or minor
  • 108,268 POSTS
Chrysler radios are known to go bad. If the fuse is good, remove the radio and have it tested at a stereo shop.
Let me know what you find.
