Replaced left front hub bearing because it was failing and had severed the sensor wire and abs light came on. Light would not go off after repair. Disconnected battery and light still on. Had vehicle scanned and "lf vehicle speed sensor" code coming up. Sensor is plugged in securely and wire is intact, but light won't go off. Advice of mechanic is to trace electrical wire from sensor harness back. How do I do that?
Mar 26, 2010 at 5:56 PM
