2CarPros - Car Questions & Answers
2000 Chevrolet Venture Repair Question
Topics covered: Gas, Dent, Engine.
Asked on February 2, 2010
2000 Chevy Venture Venture Stutters after warm up
Replied on March 22, 2010
My Chevy Venture van was doing something similar. Turned out to be a vacuum leak on the little "t" that comes off the PCV valve line. Its hidden under the triangular shaped throttle bracket. I could hear the air hissing from it. I undid the two bolts that hold the bracket down (10mm) and when i pulled the "t" out, the motor really went haywire! throttling up and down like mad until just stalling out 10 secs later... What i did: ok this is kinda redneckish, but i cut a small piece of washing machine supply line hose (smaller than garden hose). The size just happened to be perfect and i slid it on the end of the "t" and put it back in its hole... presto! No more vaccuum leak and my van is purring like a kitten now. Probly helpful to mention that after i put the throttle bracket on I hit the triangular part that covers the "t" with a hammer until it pressed down hard enough on the "t" to seal the tiny air leak it was still letting through. Hope this helps someone- sorry about the non-technical nature of this post, but it may give someone a $0 fix for their engine chugging at idle problem.
Jeramy
Tiny Answered by niz76
0 questions asked
Replied on July 9, 2011
ok this may seem stupid, lol but i'm not a pro. i have a 2000 venture and the hose circled in red is cut on my van and i need to know where it goes.
Tiny Answered by luckylynk
1 question asked
Replied on January 18, 2012
I have 2000 chevy venture with similar problem. during acceleration no problem. Once the speed and rpm steadies I get random bucking like misfire. Oddly, if I unplug the EGR valve the problem goes away. no coded from my reader accept now it shows codes for EGR being unplugged. It is not speed dependent nor gear dependent. I replaced the EGR and checked the electrical connection. Sounds like a vacuum issue but I have no idea where to go from here. Any ideas? Thanks Chris
Tiny Answered by cmnsbm
0 questions asked
Replied on January 23, 2012
Hose circled in red is the PCV hose.
Tiny Answered by rivermikerat (expert)
5,494 answers provided
Replied on July 19, 2012
Check the following -- the original poster did fix the issue and explained the fix:
http://chevroletforum.com/forum/venture-29/2000-venture-studder-problem-29946/
Tiny Answered by richard_vabeach
0 questions asked
Replied on July 20, 2012
Thanks for that information, Richard. I'm certain it will help.
