2003 Chevy Truck won't start!
2003 CHEVROLET TRUCK
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
JDGCONSTSVCS
The truck has always started! I jumped in and tryed starting it and it keeped turning over , again and again. I rolled it down the driveway onto the level street..still same. I checked all the fuses...all of them ok...I checked to see if the fuel pump was making noise, it was. I removed the top of the air filter and put a lil gas in it...still same...I put some starter fluid ,it back-fired a lil bit but still same. Battery is strong and it turns over just fine. The only past problems have been low on fuel light...low on coolent light, but that has been kept a little low due to the heater core was leaking and it seemed to be not leaking if the coolent level was kept a lil bit low, it seemed to be working fine and the tempu riture gauge has been reading normal. I don't know what else too check, or what it could be. It has alway's started right up.
Dec 13, 2009 at 4:33 PM
