1997 Chevy Cavalier
1997 CHEVROLET TRUCK
TENJES
Hi, My 1997 Chevy Cavalier (87,000 miiles) has been having problems starting up the past few weeks. It takes awhile for the engine to turn over, but then finally does. Then if I turn the car off, and start it up again right afterwards, it starts up with no problem.
So far, I have been through a new spark plug, and a few new fuel pump injectors. Any other suggestions on what could be happening, my mechanic is at a lost!
Thanks!
Mar 15, 2006 at 6:57 PM
BSINFLA2001
By slow engine "turn over" do you mean slow cranking or is cranking ok but takes long time to start? If cranks ok is the fuel pressure in specs? Is spark ok? I lean toward either a flooded engine or a pump relay problem causing no pump activity until oil pressure is readable.
Mar 15, 2006 at 7:38 PM
JPAM
  • CAR REPAIR CONTRIBUTOR
  • 307 POSTS
bump**moved to GM forum
Mar 18, 2006 at 2:07 AM
