Engine stalls at idle
1994 CHEVROLET TRUCK
50,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RUSTY DECKARD
My truck runs great at idle but soon as you put it in gear it tries to shut off. I can push the gas down enough that it will stay running but coming to a stop while pushing on the brake it isles down really low starts to lurch with the brake applied then will shut off. This only happens when it is colder then thirty five degrees outside which is a lot in Alaska. I have replaced the distributor, cap, plugs, wires, ten injectors and injector wires, IAC, TPS, pressure regulator. Still all with no change.
Oct 24, 2017 at 10:30 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
This sounds more like a transmission torque converter locked up, do me favor when you are coming to a stop slip it in neutral to see if the engine stalls. If not, out it back into gear, if it stalls you have your problem figured out.
It also can be a vacuum leak at the throttle body which is have seen before lets run down this guide for me please.
https://www.2carpros.com/articles/stall-at-idle
Please let us know what you find.
Cheers, Ken
Oct 25, 2017 at 7:15 PM
REY-GTS
Yep I had this program not in Alaska though lol. I had to replace the IAC motor all fixed! I love this site.
Sep 29, 2018 at 6:13 PM
STEVEW/94
I have checked and replaced fuel pump, regulator injectors, oxy, map, coolant, knock sensors, did a valve job and replaced distributor, coil, plugs and wires and ECM. Truck will not idle unless map or coolant sensor disconnected. Fuel has 15lbs and plenty of volume bur engine is lean, lean lean. Any suggestions?
Nov 25, 2020 at 8:16 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
The fuel pressure is to low it should be @42psi Please look at this guide it will help us.
STEVEW/94
All my specs say 9-13 lbs
DOCFIXIT
  • 18,828 POSTS
My bad thought 94 went to EFI so you are throttle body. Get your timming light hook up run truck point light at injector to see spray pattern. Should be no drips and 360 deg pattern. If not inj fouling and causing lean. Also rev up make suer both are functioning.
STEVEW/94
My timing is right on and I have installed new injectors with full 360 deg spray (checked and double checked that injectors are correct size) Installed all new O-rings so I have no drips. Cleaned IPS and IAC today with no change. It will not idle when cold, it dies and even if throttle is held to 2000rpm is still dies. After warm up it idles...but choppy. Im thinking about changing throttle body and installing adjustable pressure regulator. What do you think?
BOBBY71
  • 13 POSTS
How is the vacum??? Check egr out. may be stuck open! Or egr valve diafram broken put vacum pump on it see if it holds . And check vacum lines . before spendind anymore money
SHERILUMINA
My car has been stalling when I am at a stop sign, lights or basically whenever your foot is not on the gas pedal. The fuel system has been tested and is fine, we changed the spark plugs which seemed to fix the problem for 2 days, then it happens again. Sometimes the car runs fine, other times it does not. If i have to take my foot off the gas I have to put it in park and rev the engine to keep it from stalling. It starts fine, turns over decently, sometimes acts up when im turning it over but it always starts. Engine revs good, but as soon as you come to a stop it usually stallls out. Someone said it might be the Mass Airflow Censor, but then I read my car doesnt have one. Any suggestions? Thanx
N2K3L
Maybe check the IAC valve. From what you described I believe that is a common problem with these cars.
FIREFIGHTER EARL
it is your computer that could be causing that problem because I have the same kind of car and I got a new computer from NAPA and I put it in the same day and so far I have put 20,000 miles after that. so talk to your local NAPA and get one it only cost about 1 or 2 hundred dollars and it should be on the passanger side under the coolant container
WAYNEL
my truck will start for approx. 10 seconds then stalls, it will do it for about 10 times, then it will run with no problems. this doesn't happen all the time, it usually happens in the mornings, however it has happened when the truck was warm. Can you please help!!
Nov 25, 2020 at 8:17 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Lets start with a fresh tune up? how long ago? Then make sure the fuel pump can pass muster. New air and fuel filters? Hard start is most always tune up related...
MERLIN2021
  • 17,250 POSTS
Ok the next step is to look for vacuum leaks, get a can of spray gumout, and start spraying the vacuum hoses and manifold, When the engine changes speed, you have located a leak.
RANDERSON3991
My 1991 chevy silverado wont idle. It idles when cold but when it warms up it wont idle when you put it in gear or come to a slow down or stop. I have replaced the IAC, coolant temp. switch, worked on the EGR, fuel filter, cap, rotor, wires and plugs. Have checked everything i can think of, need help
common for the gasket under the throttle body to leak vacuum and cause stalling. see if it is broken or cracked.
NDBURBANK
We cant seem to get my 91 to idle. I had this problem beofre I had the new motor put in it. And now the mechanic working on it cant seem to figure it out either. I did a bascic tune up on it a couple months ago and all was good. then all of sudden this idling problem comes. the only reason we changed motors was milage and it was starting to smoke ike i said it had this problem before we swaped motors. and we've already redone the intake gaskets on the new motor
2CARPRO JACK
  • 11,533 POSTS
Could be a stuck Idle Air Control Valve.If you remove it from the TBI, plugged in, when the key is turned on it should go in them out.If not it isnt working
CHRISTINA SAYRE
blazer shakes and stalls when at idle and drive replaced c.converter plugs and coil what next?
LOSONE
  • 1,616 POSTS
Sounds like a vacuum leak or a bad idle air controller. Have you checked the obvious like wires, plugs, distributer cap and rotor?? The power brake booster is often a source of a vacuum leak.Good luck
UGSTEVE
Electrical problem
1991 Chevy Truck 4.3 litre engine Two Wheel Drive Automatic 140000 miles
I replaced all the sensors on the throtle body,new wires , spark plugs , cap and rotor and it ran fine but now it just misfires and will will not idle properly.If I get it started when it is cold...its a miracle to keep it running .I checked the spark theres pletty there . Pletty of fuel going to the throttle body injection.Is there a pickup coil on these that could cause the problem?
BLACKOP555
  • 10,386 POSTS
so you already replaced the IAC?
replace your Coolant temp sensor *ECT* also a bit of a note is throttle body injected TBI, are known for hard cold starting, when the fuel hits the cold plate it doesnt evaporate effectivley, but when it warms up it gets better because the plate warms up and the fuel evaporates move efficently, thats why most intake manifolds have coolant passages in them so the fuel vaporizes more efficently and doesnt condensate into liquid, because liquid gas doesnt burn.
RAULETTA
Engine Mechanical problem
1994 Chevy Truck Two Wheel Drive Automatic
OK. HOPE U HAVE SOME TIME. (sorry for cap lock). i have a 1994 chevt truck frame National RV w/ a 454. (Chassis and engine are actually 1993). I purchased it for $2500.00. apparently it was purchased used in 2006 and ran great for a couple of years. then the problems began. when the enging is started it stalls, and won't idle. if i disconnect the temp sensor then it idol's fine. under a load it doesnt run well. No error codes come up (unless I disconnest the temp sensor). on diagnostice "lean condition" came up
stuff changed:MAP,Throttlebody injectors, plugs, cap, rotor, wirers, pcv, computer
stuff checked : compression fine, stalls right out when TBI intake blocked, vacuum, fuel, fuel pressure.i reconditioned the egr which was stuck.
Nov 25, 2020 at 8:18 AM (Merged)
DR LOOT
  • 2,311 POSTS
If I had to place a bet on it I would say the EGR
RAULETTA
thanks for the reply. I can look into that next. i am in the process of removing the catilytic converter. to bypass this and chech if perhaps it's plugged. i doubt it but 3 seperate mechanics have suggested i do this.
bummer- the engine pipe is not only clamped but welded to the cat.
DR LOOT
  • 2,311 POSTS
before you go through all that work, tell me if you can hold your hand over the exhaust and plug it, is it very easy?, and how long you can hold your hand on their before you lose it, make sure you wear a glove if the truck is hot.
VETTESLAVE
Engine Starts great...runs good at highway speeds...when it reaches normal operating temp. and you stop in gear it stalls out...then starts up with no problem.
I have replaced the plugs, wires, cap, rotor, fuel filter.
  • 110,190 POSTS
Has the check engine light come on? Have you checked for vacuum leaks or EGR problems?
EDWARD REED
Two overlooked items that wound up fixing the vacuum problems causing my vehicle to stall whenever in gear and my foot not on the accelerator: EGR boot and oil filler cap.
The EGR valve boot had 2 issues: 1) the flange on the valve was not seated in the recess of the boot. Once seated properly, the stalling condition became intermittent instead of constant. When I replaced the boot, stalling became rare.
That's when I knew I was onto something. Having gone through every suggestion seen in this post, including checking and replacing everything I assumed was vacuum related, I was overlooking the operational aspect of how that "port" vacuum is created. Most of the vacuum used in an engine comes from the intake side cam housing. Any leak there cannot be overcome at idle when in gear. When you're depressing the accelerator, you often generate vacuum to spare.
With my oil filler cap so easy to remove and put back on I decided to try changing that. If it's a breeze to remove the cap, it isn't sealing.
Stalking became a thing of the past on that vehicle for months. Suddenly the symptoms reappeared in full force. I went back through all of the vacuum system and found that the oil cap, the one I just replaced, was like jelly. The rubber was softening at operating temperature. I replaced the filler cap again. Same part, same brand (Help!), and that was years ago. They must have had a bad batch of rubber with the first cap I bought.
Debug was simple on the EGR and filler cap. With the engine running and warmed up, assisted by someone holding their foot on the brake and putting the vehicle in gear, the idle can be made happy by just pushing the valve or cap down. On the EGR that was true whether it was the valve flange not seated properly in the boot, and in determining the entire boot had gone past its serviceable period.
On my daughter's car, the intake camshaft housing gaskets were leaking. Oil was seeping out, so air (and dirt) was getting in. The air getting in was causing vacuum pressure to drop enough that her car intermittently stalled in gear when warmed up, with the foot off the accelerator. The constant symptom was a grumbling engine. It just sounded like it didn't want to be bothered.
Vacuum leaks entail more than just vacuum lines and fittings.
Rubber does the opposite of almost every other material when temperature variations occur it shrinks when hot and expands when cold. This is why the symbiotic relationship between rubber and metal creates such a great seal.
One more stalling issue under the same operating conditions came about on my Chevy. The seal on the vacuum dump tube to the exhaust cam cover, another rubber boot similar to the EGR valve boot (including the flange seat) was old and tired too. I could not find a replacement. The inner diameter was smaller than the EGR boot, but otherwise identical. To fix the exhaust vacuum leak I had to resort to adding a layer of heat shrink tubing to the vacuum dump tube and two layers of heat shrink tubing to the outer surface of the boot. I don't like it, but it works. How that dump tube works I imagine is to maintain vacuum when none of the intake valves are open.
None of those issues were what I expected to include when inspecting for vacuum leaks. Add them to your checklist and you might save yourself a lot of time, money, aggravation and the failures that come with trial and error.
May 26, 2022 at 8:13 AM
  • 54,354 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
May 27, 2022 at 5:16 PM
