1990 Chevy Truck lack of power and back firing out the tbi
1990 CHEVROLET TRUCK
178,000 MILES • V8 • 4WD • AUTOMATIC
ROOTY79
i received a truck to work on and the belt had been completely shredded off the pulleys and actually wrap around some of them. i did a tune up set the engine to tdc and lined the crank pulley to zero and restabbed the distributor the rotor was pointing towards #1 cyl. in the5:30 position and the firing order on the cap is correct but the tbi is backfiring and has flames coming out of it and the lack of power still exists. is there something i'm missing i need help.
Feb 14, 2008 at 10:46 PM
  • CAR REPAIR CONTRIBUTOR
You sure you're not 180deg off on ignition timing
Feb 14, 2008 at 11:43 PM
