Very rough Idle at stop
1995 CHEVROLET TRUCK
153,000 MILES • V8 • 2WD • AUTOMATIC
FR3AKD1
  • 6 POSTS
The truck runs at speed with no noticeable fluctuation in rpms or idle, however at a stop light or in park it idles rough to the point of dying (which has done a few times). I have checked my timing, replaced the plugs and wires(AC Delco), as well as the Coolant temp sensor, PCV Valve and EGR Valve (Check Engine light flashed and I read OBD1 code). Distributor, cap and rotor are ony 1 1/2 yrs old.
Jul 19, 2010 at 4:19 PM
  • CAR REPAIR CONTRIBUTOR
Clean out the IACV and test the throttle position and manifold absolute pressure sensor.
May 2, 2017 at 11:29 AM
FR3AKD1
  • 6 POSTS
Edit: tested the map and tps, both tested withing range. Cleaned IACV. Still having issues. Anymore suggestions would be helpful.
FR3AKD1
  • 6 POSTS
Any other suggestions?
(Check engine light flashed and I read OBD1 code). Did you came up with a code?
The truck runs at speed with no noticeable fluctuation in rpm's or idle
Now in park and stop lights it idles rough. do not get it. Lets try this last one EGR pressure sensor on left side of firewall.
FR3AKD1
  • 6 POSTS
The code that was produced from OBD1 was bad EGR, so that is why it was changed. EGR pressure sensor. I cannot find anything about this part except in a Ford. Could you explain where it would be?
EGR control pressure/baro sensor on left side of firewall.
MITCHS
If somebody could please help me i would really appreciate it. Recently I had made a 600 mile roadtrip and the blazer ran fine until I pulled off of the interstate and noticed that when i decelerated the vehicle would shake alot and almost come to a stall when sitting at a stoplight, got horrible gas mileage, and the smell of gas was strong. I popped the hood as soon as i got home and noticed that somehow one of the Plug wires had come off of the distributor. So instantly i replaced it and it ran better but it is still nowhere were it was at before.
It still has a really rough idle but for the most part it seems that the gas smell has mostly gone away. I have only drove it once since it happened once it was up to speed the shaking went away. What do i do ... do i start by replacing all the spark plugs? Or may this be a more serious problem?
Any help will be greatly appreciated.
Thanks in advance.
Jan 5, 2020 at 5:55 PM (Merged)
LES DANE
  • 52 POSTS
You may have a leaking fuel supply/return line under the lower intake manifold. Also, could be the spaghetti injector tubing under the lower intake as well.
LAMONSTER
I installed the engine in a jeep and modified the air cleaner housing. The piece that had the flap that opens and closes with temp is no longer there. Now the engine doesn't want to idle when cold. The idle goes up and down until it stalls. It also smells rich.
  • 110,190 POSTS
I have to be honest. I am not sure what all has been done to make this work. If it smells rich, check to make sure the fuel pump pressure is within spec. Also, check the regulator to make sure it is not sucking gas through the vacuum hose. Check the coolant temperature sensor too. It determines how rich or lean the mixture is when cold.
Again, I am not sure what I am dealing with, so it is somewhat difficult to guide you. Also, let me know if O2 sensors are functional, what computer is running the engine, does it run good when it warms up.
RYOUNG6179
V8 four wheel drive automatic 206,000 miles.
K1500 model. Rough Idle and spark knock, have done the following:, Timing chain and gears, re-timed, cap, rotor, plugs, wires, EGR valve, EGR valve solenoid, fuel filter. It started when I was slowing down from the interstate, noticed spark knock, and a rough idle thought maybe bad gas, put in 104 octane, no difference. thought maybe knock sensor, but that does not account for the rough idle, I think. Is it possible a bad cylinder? There are no codes showing.
There is no knock at idle and it idles rough. I will check out the sensor though. I have retarded the timing to twelve BTDC and has reduced the spark knock
under a load but there is no difference in the rough idle. I have checked compression and pulled valve covers and all seems fine. All cylinders are between 90-100 psi.
It is a 350 with over 200,000 miles on it. I am sure it is low with all the wear, but it still had a lot of power. I could understand a lot of the problems associated with that many miles. Its just I go to work everything fine, fifteen minutes later rough Idle and spark knock, Lends me to believe something has failed.
I was not a gradual thing. Spark knock sensor pigtail connector looked bad, ordered another one.
MERLIN2021
  • 17,250 POSTS
Actually, if the knock sensor is working, it will retard the timing during knock periods.
Detonation/spark knock: Symptom definition; A mild to severe ping, usually worse during acceleration. Engine makes sharp metallic knocks which change with degree of acceleration.
Possible causes and corrections: Check for obvious overheating problems. Ensure initial timing is correct. Check TPS adjustment and operation. Check fuel system for low pressure or volume. Also, check for induction air leaks. Ensure ESC system is operating properly.
Ensure EGR valve is not always open. Ensure TCC system is operating properly. Remove carbon from engine with top engine cleaner. If excessive carbon exists in combustion chamber, check for excessive oil burning due to leaking valve guide seals.
Check for incorrect basic engine parts such as camshaft, cylinder heads and pistons. Ensure correct PROM is installed in vehicle. Check with dealer for latest application information.
MERLIN2021
  • 17,250 POSTS
You might want to read the codes if the service engine light is on. it will point you in the right direction. Cross these two"A" and "B" terminals as shown, then turn the key on. Count the flashes, a 22 will flash as two flashes then a short pause, then two flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with twelve. Write them down and post here. This connector is right under the middle of the dash.
https://images.2carpros.com/forum/automotive_pictures/62217_GM_ALDL95_Older_3.jpg
RYOUNG6179
I have a code reader and the only time I coded something is when I was testing a component and ran when disconnected. That is why this is so puzzling to me, usually when something non mechanical craps out I pick up a code. I got so frustrated with this truck I turned into a parts replacer, even though I check out the parts and they seemed fine. My manual lists a spark control module mounted next to the TBI But I do not have one there on my truck so that is about the only component I have not checked, because I cannot find it.
MERLIN2021
  • 17,250 POSTS
FUEL SYSTEM PRESSURE TEST TBI 1. Turn ignition off for 10 seconds. Turn ignition on, and listen at fuel tank for fuel pump operation. Pump should run 2 seconds (20 seconds on models with fuel module). If fuel pump runs, go to next step. If fuel pump does not run, go to step 7). 2. If fuel pump runs, turn ignition off. Verify fuel tank has fuel. Relieve fuel pressure. See FUEL SYSTEM PRESSURE RELIEF. Remove air cleaner, and plug air cleaner vacuum ports (if equipped). Disconnect fuel line between throttle body and fuel filter. Install Fuel Pressure Gauge (J-29658A) and Adapter (J-2968A-85) between steel fuel line and flexible hose, ahead of in-line fuel filter. 3. Turn ignition on, and note reading on pressure gauge. If fuel pressure is 9-13 psi (.63-.91 kg/cm 2 ), no problems are present. If pressure is less than 9 psi (.63 kg/cm 2 ), go to step 5). If pressure is greater than 13 psi (.91 kg/cm 2 ), turn ignition off, and bleed fuel pressure. Disconnect fuel return line downstream of pressure gauge. Insert return line into a gasoline container. 4. Turn ignition on. If pressure is now 9-13 psi (.63-.91 kg/cm 2 ), correct restriction in fuel return line between disconnected point and fuel tank. If fuel pressure is greater than 13 psi (.91 kg/cm 2 ), check for restricted return line (including fuel filter) downstream of pressure gauge. If no restrictions are present, replace fuel pressure regulator (TBI 700) or fuel meter cover/pressure regulator (TBI 220). 5. Check for restricted line between in-tank fuel pump and pressure regulator. If fuel line is okay, disconnect injector connector. Turn ignition on. Gradually pinch fuel pressure gauge outlet hose. Note pressure. 6. If pressure is greater than 13 psi (.91 kg/cm 2 ), replace fuel pressure regulator (TBI 700) or fuel meter cover/pressure regulator (TBI 220). If pressure is less than 9 psi (.63 kg/cm 2 ), check for faulty fuel pump or incorrect part. Check fuel pump coupling hose and pump inlet filter in fuel tank. On models with dual fuel tanks, check for faulty fuel tank selector valve and meter switch. 7. Apply 12 volts to fuel pump test connector. For fuel pump test connector location, see underhood engine component views under COMPONENT LOCATIONS in SYSTEM/COMPONENT TESTS article in this section. If fuel pump now runs, repair open in fuel pump relay drive or power circuit or repair faulty fuel pump relay. To test relay, see SYSTEM/COMPONENT TESTS article in this section. 8. If fuel pump does not run with 12 volts applied to fuel pump test connector, repair open in fuel WARNING: Begin fuel system trouble shooting and diagnosis with fuel system pressure test. Relieve fuel system pressure before disconnecting any components or installing fuel pressure gauge. CAUTION: DO NOT pinch off fuel return line completely. DO NOT allow fuel pressure build-up to exceed specification, as damage to fuel pressure regulator may occur. Check for vacuum at PCV, remove PCV frm hose, any vac? If low check for slit hose, or a common problem on high milage vehicles is TBI carboned up at the base. Remove TBI and inspect the bottom, it may be gunked up. You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody Torque Converter Clutch (TCC) Solenoid Disconnect harness connector to TCC solenoid. Measure resistance between TCC solenoid terminals. SeeFig. 10-Fig. 15 . Solenoid resistance should be greater than 20 ohms. TIMING CONTROL SYSTEMS (C-4 & C-5) C-4, Electronic Spark Timing (Gasoline Engines) An open or short to ground in Electronic Spark Timing (EST) or by -pass circuit will cause ECM to turn on Malfunction Indicator Light (MIL) and confirm fault causing Code 42 is present. Refer to appropriate TESTS W/CODES article in this section. C-5, Electronic Spark Control (ESC) Circuit (Gasoline Engines Except 2.5L, 4.3L Turbo & Vehicles With 4L60E Transmission) 1. An open or short circuit on ESC wire to ECM will cause a loss of 12-volt ESC controller signal. This will cause ECM to fully retard ignition timing. 2. If a scan tester is available, connect tester to Data Link Connector (DLC). Using a metal object, tap on engine next to knock sensor and note knock parameter. Knock should be indicated on scan tester. 3. If a scan tester is not available, backprobe ECM ESC signal terminal with a DVOM. With engine idling, 8-12 volts should be present at this terminal. Using a metal object, tap on engine close to knock sensor. Voltage signal at ECM terminal should drop to zero volts, and return when knock signal ceases. 4. If signal does not respond as described, check knock sensor signal to controller signal. On vehicles equipped with automatic transmission, it may be necessary to place transmission in Drive for timing change to occur. See KNOCK SENSOR under ENGINE SENSORS & SWITCHES. POSITIVE CRANKCASE VENTILATION Required Service - The PCV system may require service for obstructions if any of the following conditions exist:  Rough Idle  Stalling or Slow Idle Speed  Oil Leaks  Oil in Air Cleaner  Sludge in Engine A leaking PCV valve or hose could cause:  Rough Idle  Stalling  High Idle Speed If engine idles roughly, check for clogged PCV valve and for plugged or broken PCV hoses BEFORE adjusting idle. Check correct PCV valve application to ensure the correct valve is fitted. Replace PCV valve if required. Checking PCV Valve Function (Except 2.5L) 1. Remove PCV valve from rocker cover. Run engine at idle. Place thumb over open end of valve to check for vacuum. If there is no vacuum at valve, check for obstruction in manifold port, hoses or PCV valve. Repair or replace as necessary. 2. Turn engine off. Remove PCV valve. Shake valve and listen for rattle of check valve inside PCV valve. If a clear rattle is not heard, replace PCV valve. 3. Visually inspect valve for varnish or deposits that may make PCV valve operation sticky, restricted or incompletely seated. Replace if necessary. 4. Engine must be sealed for PCV system to function as designed. If leakage, sludging or dilution of oil is noted and PCV system is functioning properly, check engine for cause and repair as required to ensure PCV system will continue to function properly. 5. Since an engine operating without any crankcase ventilation can be damaged, it is important to replace PCV valve and air cleaner breather at regular intervals (at least every 30,000 miles). Check all hoses and clamps for failure or deterioration. ELECTRONIC SPARK CONTROL (ESC) MODULE REMOVAL & INSTALLATION Turn ignition off. Remove bracket-to-firewall screws. Rotate bracket to access ESC module. Disconnect ESC module harness connector. Remove ESC mounting screws and remove ESC. To install, reverse removal procedure. NOTE: On models equipped with external ESC module, ESC is located on bracket behind distributor, mounted to firewall. The other thing to check on high mileage trucks is the timing chain, it may have jumped by 1 tooth and this will allow it to run, but real diesely like1 Check timing marks and #1 at TDC, Compression you gave is low...150 or so is the avaerage.
https://images.2carpros.com/forum/automotive_pictures/62217_k1500TCC_1.jpg
Installation 1. To install, reverse removal procedure. To insure correct timing of distributor, install with rotor correctly positioned as it was before distributor was removed. 2. If engine was cranked after distributor was removed, remove No. 1 spark plug. Place finger over No. 1 cylinder spark plug hole. Crank engine slowly until compression is felt. Align timing mark on pulley to "0" on engine timing indicator. Turn rotor to point to cylinder No. 1 spark plug tower on distributor cap. Complete distributor installation. Start engine and check ignition timing.
https://images.2carpros.com/forum/automotive_pictures/62217_dista_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Dist_2.jpg
If it has esc, it's on a brackett behind the distributor, mounted to firewall.
PAULKING29935
1994 Chevy K1500 213000 miles on it. The truck has been starting to bounce around when idleing in park and when you are in gear at a light or stop sign. I overhauled the throttle body and tested the o2 sensor it was good. problem went away for a while now it is getting worse. was told that the next thing to do would be to check the egr valve. what do you think. also i have already had the intake off due to leaking antifreeze and when i did i cleaned everything out of the valley.
Jan 5, 2020 at 5:56 PM (Merged)
Clean out the idle air control valve and the EGR valve and see what happens. Also, look for vacuum leaks.
PAULKING29935
i cleaned out the IAC when I did the throttle body still have to do the EGR valve. what do you think is the best thing to use when cleaning the EGR? I have a sonic cleaner that I used when I did the throttle body. also, i already checked for vacuum leaks that is all good.
If it works for you go for it otherwise carburetor cleaner or a de-carbonizer of such bore brushes.
SHAY
my car has been running rough and stalling out. to be more specific, car runs rough from the start and when the car has warmed up it will begin to act like it wants to stall. if I'm going down the highway and slow to make a turn or come to a stoplight, it will stall as I'm slowing down. sometimes it will die as I'm accelerating as if the fuel just cut out. When it stalls it takes 10-30 minutes before I can get it started again.
Once when it stalled I discovered that there was barely any fuel coming out of the injector.
I have replaced the injector, fuel filter, and sparkplugs. whenever I scan the computer, I get no codes, even when it has just stalled.
I'm not sure what to check next so I would greatly appreciate being pointed in the right direction.
Today the car finally gave me a code 34 so I replaced the MAP sensor. car still running rough but left it run for a short while and it didn't stall so far. a storm moved in so I had to shut off the car and go inside. will let it run longer tomorrow.
while changing the MAP sensor I noticed a crack in the TB housing. could this be causing the roughness? I'm guessing that this may be causing a vaccum leak.
I have since inspected and cleaned the IAC valve and tested the EGR valve. engine stumbles when egr plunger depressed, so that is okay. still present is the loping/surging idle. Also replaced TB Housing (well i guess it's acurately called the air box or air cleaner top).
more to add: I got a code 35 (iac valve), replaced it, hooked everything back up. started the car and it was running great but the engine light kept coming on with the same code for the IAC. I reset the computer and it was still giving the same code. I got under the hood to recheck the valve and realized that I forgot to plug in the electrical connector. I plugged it in and now the car is running just as bad as before if not worse. it idles fine in park, but if I'm just sitting there in gear the idle is low and rough and when it starts to stall the engine revs itself. after letting the car idle in drive for about 20 minutes it finally stalled again and the computer gave me no more codes.
summary of replaced parts:
fuel injector
fuel filter
spark plugs
MAP sensor
IAC valve
tested EGR valve
unplugged TCC solenoid
SWEEP2WIN
  • 21 POSTS
Try pulling the plug on TCC solenoid. That should solve your highway to stop problem.
SHAY
[quote:732fd9ec69="sweep2win"]Try pulling the plug on TCC solenoid. That should solve your highway to stop problem.[/quote:732fd9ec69]
thanks.
SHAY
Found the problem. the infamous vacuum leak. plugged it and the car is purring like a kitten.
FATRICH
My Lumina Euro idles a little rough sometimes, but i am not too worried about that, the main problem is that when it gets hot ( running temperature) it sometimes sputters then stalls. if i give it gas it will restart and i have to keep giving it gas or it stalls if i try driving after the initial stall it barely wants to get out of its own way. i have seen a lot of talk about clogged catalytic converters and also the torque converter lockup solenoid, but i have no idea what to do. The computer comes up with five codes (1)-23 manifold air temp to low,(2)-21 throttle position sensor/ckt high,(3)-15 coolant temperature signal high or open (4)-53 system voltage to high (5)-43 ESC module or sensor circuit problems. also, the scanner says that my systems voltage is 25.5 volts and the fuel pump is getting 25.5 volts when it is acting up. Please help!
LARRYLOSS
Vehicle has a rough cold idle, usually in colder weather which can last from 15-45 seconds and then abrurtly smooths out.
Previous advice was to replace idle air control valve which was done but this has not corrected the situation.
Try the coolant temperature sensor its job is similar to a choke on a carb system to give fuel during initial cold starts.-Cold engines needs more fuel to start
MIKECOKER
1987 chevy 454 idles rough but clears out at 35 mph
done a compression check is uneven both banks and have retimed distributor to top dead center ,plugwires are new and plug also cap and roto i might have others questions as we go on the 45r
MIKE H R
  • 3,094 POSTS
has the cam been changed in the 454? Diferent cams make the idle run different. you say the compression is uneven in both banks. How much of a diference is there? What work has been done on engine?
