2002 Chevrolet Tahoe Repair Question
Topics covered: Panel, Cabin filter.
Asked on May 4, 2007
Chev, Tahoe, 2002, 103000, 5.3L
I would like to replace the air cabin filter. Where & how do I remove the old one?
Answer
Replied on May 8, 2007
You need to access it from the passenger area of the dash. IF you open the glove and press in on the left you can pull the glove comparment away to access the tab the arrow is pointing at, release it.
Under the dash there will be 4 screws that hol a panel up. remove and lower the panel. The tab you released has a small bolt in it toward the back, remove it and lower that piece (#1 on 1st drawing) that the tab is attached to. Pull down on the filter and put the new one in. reassemble
