2CarPros - Car Questions & Answers
1999 Chevrolet Tahoe Repair Question
Topics covered: Noise, Chirping, Idler pulley.
Asked on February 8, 2010
1999 Chevy Tahoe Chirping In Front of Engine
Noises problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic 125000 miles
Thinking about purchasing this 1999 Tahoe for my son. I've driven it about 70 miles so far, and there is this chirping sound in the front of the engine, but I am unable to narrow it down to a specific part. Serpentine belt appears to have been replaced, but I'm not sure if it is the problem. Noise gets a little louder with an RPM increase. Power steering fluid is good. Any ideas?
Avatar Asked by NQBUS
Answer
Replied on February 8, 2010
It may be a belt noise. You can give a quick blast of silicone or thin lube and it may stop it for a moment. Then if you take some valve grinding compound and smear it on both sides it will remove any glazing.
Cheap belts are more prone to noise.
A weak tensioner can add to a belt noise. Lastly a pulley may be the source. Try rocking each pulley to feel for any movement. Remove the belt and feel each pulley for any roughness.
Tiny Answered by Service Writer (expert)
9,955 answers provided
Replaced the pulley on the tensioner, and about 85% of the chirping went away. Spun the idler pulley while the belt was off and I think it may be accounting for the only minor chirp left. Don't hear it now when the RPMs are up, only when it comes back down, and then only a little.
Tiny Response from NQBUS
1 question asked
Spoke too soon, the noise is back. If the tensioner itself is weak it can cause this? Is that more likely than the idler pulley?
1 question asked
Replied on February 9, 2010
Original tensioner? good chance.
I have had multiple sources of it on my truck. Reasonable to expect wear on all the pullies and contributing, but a weak tensioner can be a source for sure.
Look closely at the tensioner mounting, IT the arm of the tensioner pulled in enough to see a gap that is unequal where it mounts?
