1999 Chevy Tahoe
1999 CHEVROLET TAHOE
136,000 MILES • V8 • 4WD • AUTOMATIC
BRI1130
I just bought this vehicle about 3 weeks ago. I had it checked out by a mechanic. The only thing they could see was the idiler arms need replaced and the transfer case seal needs replaced. About 4 days after i had it i could tried to start it and it sounded like it was but didn't have that fire to finally start. Had it towed to have it looked at and was told it was the fuel pump. After a week finally had that replaced. Got it back and had it for 3 more days went to start it and it started right up put it in gear (which has always been hard to put in gear) backed up about 2 feet and its like the back wheels lock up. put it back in drive it will barely go cause its like the back wheels are locked up. It has set for 4 days. Now if you start its hard to get in gear and when you do get it in gear you cant go forward or backwards at all. What should i check for now? What could it possibly be?? Please help!!!!!
Oct 10, 2008 at 3:35 PM
