2CarPros - Car Questions & Answers
Chevrolet Suburban Repair Question
Topics covered: Clutch, Engine, Engine compartment.
Asked on August 13, 2007
Suburban AC clutch won't engage
1999 Suburban, 33K miles. The AC clutch doesn't engage. Checked fuses 1 interior OK, One in engine compartment OK. Swapped identical relay in engine compartment, no change. No current at AC clutch plug.
No clutch engage when jumping from battery to prongs on clutch assembly. Added about 1/2 can of gas, while engine was running but compessor was not. It appears that there are two problems. The clutch not engaging, are the prongs + and - or is it internally grounded? Why no current at the engine side of the plug?
Avatar Asked by cerecerely
Answer
Replied on August 14, 2007
Check the low pressure switch on the accumulator. Jump the connector and see if the compressor will run, do this only briefly so you don't burn out the compressor! Be ready to charge the sysem then jump the switch.
Tiny Answered by merlin2021 (expert)
18,145 answers provided
