Only the rear top bulbs on either side light up when I press the brake (3rd light works fine btw) - lower bulbs stay dark. I swapped the upper and lower bulbs around and they all light up so bulbs are fine.
Also, not sure if it's related, but battery seems to drain slowly/can't hold a charge.
How/what sequence should I troubleshoot a) bad battery b) bad battery caused by brake light issue above c) bad battery because alternator not charging correctly.
I don't see any warning lights indicating that I'm having a charging/alternator issue though.
Thx
Thx
Oct 13, 2008 at 4:48 PM
