My chevy just started having a strong smell of coolant when I turn my heat on and gets worse on defrost. The temp is not getting up to normal either. Will running my truck with this if it is a leak be alright as long as I dont run my heater and how difficult is it to change heater core out?
SPONSORED LINKS
Wednesday, January 28th, 2009 AT 7:31 PM
BILLYMAC
MECHANIC
Hi if your truck don, t run low on coolant it will not hurt it. And you may as well use the heater because makes no diff if on or off. Yes kind of a big job to replace. Time consumeing. Billymac
Wednesday, January 28th, 2009 AT 7:44 PM
CARTER96
MEMBER
Is there anything I could use for a quick patch for a few weeks until I can get to changing it out? Also does the entire dash and ac lines need to be disconnected to change out core?
SPONSORED LINKS
Wednesday, January 28th, 2009 AT 7:51 PM
BILLYMAC
MECHANIC
Hi you can put some cooling system sealer in it. There are many kinds at the parts store. And yes a/c and heater lines will have to be removed. Billymac
Wednesday, January 28th, 2009 AT 7:57 PM
CARTER96
MEMBER
Is it necessary to flush system before adding the liquid glass stop leak or can it be added straight to system than flush after?
Thursday, January 29th, 2009 AT 8:46 AM
BILLYMAC
MECHANIC
Different types work difff ways you will have to read the instructions. But most will mix with antifreeze. Billymac
