Okay let me start at the begining. a week ago i noticed a bog in the low parts of the gears. 2 days ago i was at at school and i came out and the truck just wanted to crank and crank but would not turn over, so i had it towed home. the next morning i started trouble shooting. i checked the valve on the fuel line next to the throttle body and no pressure. next i removed the connection at the fuel filter to see if i could get gas to spray out when i turned on the ignition. nothing. i checked the relay and it was fine. and i looked over all the fuses although i did not see one labeled fuel pump i checked them all. so i figured it must be the fuel pump so i replaced it and im still getting nothing. Someone said fuel pump/oil pressure switch
Oct 29, 2008 at 12:49 PM
