2CarPros - Car Questions & Answers
1996 Chevrolet S-10 Repair Question
Topics covered: Steering, Air bag, Power distribution center.
Asked on January 30, 2010
1996 Chevy S-10 Location of Turn Signal Flasher
Electrical problem
1996 Chevy S-10 6 cyl Two Wheel Drive Automatic
Does anyone know definitively where the turn signal flasher switch is located on a 1996 Chevy S-10 Pickup? I have been told inside the steering column housing but I removed bottom plate and see nothing that looks like it up in there. Nobody at parts stores or even the Chevy dealerships I called are any help. Thank you for any help you can provide.
Avatar Asked by Gahan
Answer
Replied on January 30, 2010
TURN SIGNAL LAMPS FLASHER
I/P Wiring (Center)
http://www.2carpros.com/forum/automotive_pictures/12900_tsf1_2.jpg
Power Distribution Center
http://www.2carpros.com/forum/automotive_pictures/12900_tsf2_2.jpg
The Turn Signal Lamps Flasher is located in the Power Distribution Center. The Power Distribution Center is located in the Instrument Panel below and in front of the Radio.
Turn Signal Switch
Inflatable Restraint Steering Wheel Inflator Module
http://www.2carpros.com/forum/automotive_pictures/12900_tssc1_1.jpg
Steering Column Assembly
http://www.2carpros.com/forum/automotive_pictures/12900_tssc2_1.jpg
WARNING: Refer to Air Bags and Seat Belts/ Air Bags (Supplemental Restraint Systems)/ Service and Repair/ Air Bag System Disarming & Arming.
1.Remove ignition lock.
2.Remove shift lever clevis, then the lever from vehicle.
3.Remove wire harness straps, then disconnect steering column bulkhead connector from vehicle wire harness.
4.Disconnect turn signal switch gray and black connectors from column bulkhead connector.
5.Remove pan head tapping screws, then the turn signal switch assembly from column.
6.Reverse procedure to install. Torque pan head tapping screws to 53 inch lbs.
Tiny Answered by rasmataz
68 questions asked
