Can you tell me how to remove the windshield wiper arm from the drive Sprocket on the drivers side of the windshield.
Saturday, February 23rd, 2008 AT 8:42 AM
MERLIN2021
MECHANIC
Here is the instructions and diagrams to help you change the wiper arm out. I would apply pressure then shock it with a hammer. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Saturday, February 23rd, 2008 AT 8:50 AM
CARGUY51
MEMBER
Thanks for the Reply. I love this site
Saturday, February 23rd, 2008 AT 8:59 AM
MERLIN2021
MECHANIC
Good to hear, please use 2CarPros anytime we are here to help.
Saturday, February 23rd, 2008 AT 9:53 AM
BLACK_0726
MEMBER
1 POST
2000 CHEVROLET S-10
2WD
AUTOMATIC
150,000 MILES
How to tighten loose windshield wiper arm on 2000 Chevy s-10?
Wednesday, October 14th, 2020 AT 1:38 PM
(Merged)
JIMMYJAMES
MEMBER
When you say "wiper arm" I take it the windshield wiper arm attachment to the wiper transmission the spline where the wiper arm attaches to area is loose. The wiper arm needs to be clocked 90 degrees then fully depressed onto the wiper transmission. When the arm is fully engaged to wiper knop it should click and fold down to the vertical position. If wiper arm has a nut under a cover on the wiper arm simply tighten it if your in proper alignment. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SPONSORED LINKS
(Merged)
D3WITT
MEMBER
1 POST
1999 CHEVROLET S-10
6 CYL
4WD
AUTOMATIC
119,000 MILES
The driver's side wiper arm just stopped working. The passenger side still works fine, and it seems that the motor is still running. Could the wiper arm be stripped or would it be the cam it attaches to? Also, how do I remove the wiper arm without damaging anything.I pulled and wiggled and it won't budge, is there a retainer nut?
(Merged)
2CARPRO JACK
MECHANIC
The whole end is the cover, under it there wil be a nut. Sounds like the arm broke the pivot bushing, no big deal to fix
(Merged)
KOOLBREZ12
MEMBER
1 POST
1998 CHEVROLET S-10
2WD
AUTOMATIC
On a 1998 chevy s-10 truck how do u remove the windshield wiper arm?
(Merged)
HMAC300
MECHANIC
If it doesn't have a bolt or nut holding it on there may be a little lock that will come loose. If not that then it will just pull off but that is better done with a tool to take it off or a flat screwdriver to help pry it off.
(Merged)
ROSCOE52
MEMBER
1 POST
1993 CHEVROLET S-10
6 CYL
2WD
MANUAL
200,000 MILES
I would like to remove wiper arms to take off body panel underneath. My seal around hood arms are leaking
(Merged)
MASTERTECHTIM
MECHANIC
Pull the arms up then look at the base of the arm there is a little hole that goes straight through. Put a nail in it or cotter pin. Then let pressure off of arm and wiggle it, it should pop off. Hope this helps
Wednesday, October 14th, 2020 AT 1:39 PM
(Merged)
JAMIE614
MEMBER
If that does not work there may be a tab lift arm look for a little tab on the side of base pull that tab out it does not move very far that will hold the orm in the air then wiggle see if it comes off
SPONSORED LINKS
(Merged)
SISKO89
MEMBER
1992 CHEVROLET S-10
6 CYL
2WD
MANUAL
153,274 MILES
I need to replace the windshield wiper arms.
How do the windshield wiper arms come off?
(Merged)
MECHANIC
There are two ways they can be secured. One is by a bolt under a cover where the wiper arm is attached. The other has a slide clip that is at the base of the arm. Is will slid open and then the arm can come off.
