Mechanics
CHEVY FUEL PRESSURE REGULATOR
1991 Chevrolet S-10
Engine Performance problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic 69700 miles
i need to know if there is any special way that I have to replace the fuel pressure regulator
Sldrchris85
February 13, 2010.
Properly relieve the fuel system pressure and disconnect the negative battery cable.
Disengage the vacuum line from the pressure regulator.
If applicable, disengage the fuel line(s) from the regulator.
Remove the retaining bolts, then separate the regulator from the fuel rail assembly.
http://www.2carpros.com/forum/automotive_pictures/261618_1_122.jpg
To install:
Install the regulator to the fuel rail and secure using the retaining bolts.
If applicable, engage the fuel line(s) to the regulator.
Engage the regulator vacuum hose.
Connect the negative battery cable, then pressurize the fuel system by cycling the ignition (without attempting to start the engine) and check for leaks.
Bluelightnin6
Feb 13, 2010.
