Engine Mechanical problem
1975 Chevy Monte Carlo
please help oil smells like gas...gm 350 330 hp crate motor,new holley hp750 vac secondary carb, mechanical fuel pump,car runs fine check fuel level through clear site plugs in carb, fuel is at bottom of screws, im getting gas runs ok plugs little black around outer ring but center electrode is clean ,changed oil drove around block came home dipstick smells of oil again ?????can fuel pump diaphram be bad and still work as it should the car runs fine right now
Mar 15, 2010 at 12:15 PM
