Turn Signal flasher location
2003 CHEVROLET MALIBU
JBMANNER
Sometimes when I use the turn signals or the emergency flashers, when they are turned off the clicking noise keeps on to the point that the signal warning bell chimes. I don't know if this a relay or flasher problem and can't locate it under the dash board. It sounds like it is coming from behind the radio/heater area. I found the relay at O'reilly's Auto parts but don't want to purchase it since I don't know if this is what I need or where whatever part I need goes.
Feb 20, 2010 at 8:33 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
They had big problems with the hazard switch (flasher for both systems blinker and hazard) in these cars which is where the flasher is located. Here is a wiring diagram and a guide to help you test and confirm the problem and the location of the flasher below.
Diagrams (below)
Cheers, Ken
Jul 29, 2017 at 3:32 PM
TOM789
My turn signal stopped working. My hazard lights still work and everything else on my turn signal controls work. Wipers, flashers, and high beams.
So I replaced the turn signal switch but the turn signal is still not working.
So the only thing it can be is the turn signal flasher. I'm trying to find the location of the flasher but I cannot find any info in my car repair Manuel or owners Manuel.
Thanks
Jul 29, 2017 at 3:33 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The switch and relay are built into one unit and are located on the dash, to the right of the instrument cluster.
BRANDYKNOLL
Electrical problem
2002 Chevy Malibu 6 cyl Four Wheel Drive Automatic 86000 miles
I have found out that the reason my turn signal works from time to time is the turn signal flasher, I have bought a new one to put in but now I can not figure out whare it goes I got under neath the steering collumn and pulled off the cover but I can not see the part... Please tell me whare to replace this item thank you brandy
1000DLRBILL
[quote:0844cbc82a="brandyknoll"]Electrical problem
I have found out that the reason my turn signal works from time to time is the turn signal flasher, I have bought a new one to put in but now I can not figure out whare it goes I got under neath the steering collumn and pulled off the cover but I can not see the part... Please tell me whare to replace this item thank you brandy[/quote:0844cbc82a]
The turn signal flasher is common to the hazard warning flasher. It is located on the Hazard push button on the dashboard.
