dash does not light up?
2005 CHEVROLET MALIBU
38,255 MILES • 4 CYL • FWD • AUTOMATIC
SCHAEJ01
I have a remote starter installed in my car, and I had a set of speakers installed in my car. After I had my speakers installed there us a lock symbol lit up on my dash, also the pointer on the speedometer does not light up anymore. How can i fix this and what is wrong.
Dec 7, 2007 at 11:49 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
[quote:a5d8d720c9="schaej01"]Other Category problem
2005 Chevy Malibu 4 cyl Front Wheel Drive Automatic 38255 miles
I have a remote starter installed in my car, and I had a set of speakers installed in my car. After I had my speakers installed there us a lock symbol lit up on my dash, also the pointer on the speedometer does not light up anymore. How can i fix this and what is wrong.[/quote:a5d8d720c9]
Did you remove the cluster out
did one of the bulb fall off
and was put in the wrong place
Dec 9, 2007 at 10:00 PM
DMJ68164
I have automatic light in my 2003 Chevy Malibu, and recently the dash board and radio lights do not come on at night. The headlights work fine. The radio works fine; just no lights. During the day the radio lights do come on, and all of the non-backlight lights (IE. Door Ajar, Check Engine, Airbag, etc...) works on the dash during both the day and night. I have checked all of the fuses, but none were burnt out and all passed on a fuse checker. Help!!
Apr 25, 2020 at 1:26 PM (Merged)
JDL
  • 16,098 POSTS
Use a voltage tester at the instrument lamp fuse, with lamps turned on. If no voltage backtrack the circuit.
DREKA95
So my dashboard light is out in the background, the other lights come on like if the gas is low or its low on water but at night when i have to drive the dashboard does not light up i have checked the fuses and they are good. so whats the problem?
  • 54,354 POSTS
If it is an LCD dashboard then the instrument cluster illumination driver has gone out. This means the cluster will need to be rebuilt.
Here is a guide that will show you what you are in for when replacing the cluster.
https://youtu.be/_HEC44xENxw
Best, Ken
CASHONLY
It all started when I dropped my key fob in the snow. My door lock fuse keeps popping when I engage the passenger lock switch (the driver side doesn't work, I don't even hear the relays click when I use that one) and at night my dash lights go out as well as my radio display. Though I still can use it, play cd's or radio. My car will also not be able to start after running just the radio for 10 minutes or it not being started up for 2-3 days. I thought the driver side lock might have been drawing power so I popped it out but my problems persist.
RHALL77
  • 3,361 POSTS
sounds like you may have a wiring problem. i dont think your key fob would have anything to do with it. I would take it to a profrssional to have it looked at. Your lights may have the same problem right next to the door lock concern in the same location on the vehicle.
SHERRIEMYERS
Just had a bunch of work done on car. Replace fuel pump, new plugs, new wires, change radiator hose , flush radiator, new belts -replace roteres new brakes clean engine, change oil.
My husband did this as a favor while I was out of town. He took it to a unknown mechanic. When I first drove the car I noticed that the air conditioning was not functioning as before. I seemed that the dash board controller was not working- air was very cold but dial to say where air is expelled was not working. No matter where you said- feet- dash- feet& dash- defroster- etc It was allways the same. You could feel the cold air - lightly comming at dash and feet, no matter how you changed the dial. Also fan controll was either low or high- and high not as high as before. I took it back to mechanic they said it was either a vacume leak or the dash board controler. They then tested it and said it was the dash board controler. I have replaced the dash board controller and the same problem exists. I think it is a vacume leak. The controller dial for direction of air expell is vacume controlled. I tried to back track these little air hoses but lost them in a conduit under the dash board. Any Ideas?
DOCFIXIT
  • 18,828 POSTS
Hi
On controler purple hose is vacuum source from engine check for vacuum. Red hose goes to mode accutuator see if vacuum is there when mode is selected. If these have vacuum then mode select acuator is faulty.
Hope this helps
Thanks for donate
SHERRIEMYERS
Hi Docfixit- I checked the purple hose and no vacuum. I removed the controller and then unplugged the mode selector and placed my finger tip over the hole where the purple tube is - and nothing. The car was running and the air was on.
https://images.2carpros.com/forum/automotive_pictures/373526_purple_hose_controler_1.jpg
DOCFIXIT
  • 18,828 POSTS
O.K. purple hose must go through firewall and attach to intake manifold for vacuum. I can't tell from info i have where but search around it will be only hose through fire wall. will most likely be black in engine compartment. And should have a check valve in line.
SHERRIEMYERS
I have tried following the purple hose through the fire wall with no luck - I have taken the glove box out and it looks like the group of hoses enters into some kind of conduit and I can not see any thing from the inside of the fire wall - any Idea where on the intake manifold it might connect?
DOCFIXIT
  • 18,828 POSTS
It goes into the wiring loom then out to enginel Look at top engine toward rear see the wirng loom out of it comes a vac line it should be purple but by now it may have faded to white, it connects to intake next to fuel pressure regulator.
JERRY_GIBSON
The dash, radio, and air conditioning lights are out, but the fuses are good. How do i fix this? I don't know what the problem is!
RENAUDTN
  • 636 POSTS
Go to a dealer and have your BCM scanned.
LEE.WILKERSON
On my '98, there is a one-transistor regulator mounted to a bracket above the brake pedal near the steering column. T0-3 case - 2N3055 or ECG 130 perhaps. More 2 come...
JAYINYOFACE
1999 Chevy Malibu Automatic
I drove through what I thought was a low flood and sure enough, my car stalled. i was going about 8-10mph. the water was not above the hood. I did not try to turn it on in the water, just had it pushed out of the street and let it sit overnight. Yesterday there was no sound at all when I tried to turn it on. Today, there is kind of a screech then a click. The dashboard lights come on and the ac blows air, not cold. What do I do now? How do I get my car running again? detailed answers would help me greatly!
Sounds like No Crank-You might wanna start with the connections at battery/starter, starter, park and neutral position switch and ignition switch.
KIMMH012
All the warning lights come on, check fuses on both sides and underhood, they all have power, tail lights work.
Replaced dimmer switch, replaced light/wiper switches
I still have no dash lights....hard to drive at night....
Do you have wire diagram?
BMRFIXIT
  • 19,053 POSTS
does the radio and clock and the other dash light if any work and dim
if so u need to replace the light bulbs in the back of the instrument panel
if not turn light on and check fuses
KIMMH012
[quote:868fea8279="BMRFIXIT"]does the radio and clock and the other dash light if any work and dim
if not turn light on and check fuses[/quote:868fea8279]
it is a walmart special radio - and the lights do come on....
what light bulbs in the back of panel? all the warning lights are working....headlights, highbeam on dash..these all work...just no night lights to see panel.
also noticed that the shifter lights don't work - the one between the seats...can see at night...
They all use to work, then just one day started the car and NO dash lights
BMRFIXIT
  • 19,053 POSTS
turn light on and check the fuses again
check headlight switch
check wiring
radio panel lights and shifter light all come from one source
