I have a 1996 chevy lumina 3.1 v6 when the car is cold below 0 the car starts fine if the outside temp get above 0 you have to push the gas pedal down half way to start i have change the MAF, IAC valve, check fuel pressure it 42 psi, replace Throttle position sensor EGR value tested the MAP sensor and still have the same problem
Jan 11, 2010 at 10:42 AM
